1. Welcome to Recreational Flying, the Home of Recreational and GA Pilots, Aircraft and Aviation. Please register, it's FREE to use ALL our great features. Hi
Jabiru 12 Pole Alternator modification / upgrade
Discussion in 'Jabiru' started by Bluboyz, Oct 3, 2013.
  1. Bluboyz
    Bluboyz New Member
    Aug 2, 2012
    5
    4
    Country:
    Country
    Jabiru Au - has a modification procedure for their 12 pole alternator upgrading it's useful rpm charging range, and they have released an Engineering Report to this effect.
    Basically this involves changing the present stator winding's terminations from a parallel connection to a series configuration, and this should produce 12 volts @ 900 rpm instead of 12 volts @ 1800 rpm, and may assist with battery charging during low rpm operations although limited.
    www.jabiru.net.au/images/AVDALSR087-2_12_Pole_Alternator_Mod.pdf or can be found under:- Manuals, Maintenance Persons Information.
    Happy Landings
  2. frank marriott
    frank marriott Well-Known Member
    Nov 19, 2008
    1,481
    Aircraft:
    J230
    Townsville
    1,355
    Country:
    Country
    One done locally, and works as listed.
  3. Bruce Tuncks
    Bruce Tuncks First Class Member First Class Member
    Oct 18, 2007
    698
    Aircraft:
    Jabiru SK, Libelle
    Gawler, South Australia
    667
    Country:
    Country
    I wish my regulator was charging closer to 12 volts than it does. With a digital meter connected directly to the battery, the voltage reads 14.49 volts as soon as the charge used for starting is replaced, and this is usually even before takeoff.
    Now the advice about charging voltages is that 14.2 is a sensible maximum , and 13.8 is better for long flights if you want to maximise the life of the battery.
    Does anyone know if it is possible to adjust the output voltage of the Jabiru regulator?
    regards, Bruce
  4. geoffreywh
    geoffreywh Active Member
    Nov 28, 2006
    793
    338
    Country:
    Country
    not adjustable Chinese unit (in the unkindest way) Check with City Auto Electrics in Melbourne, ( Motorcycle electric specialists, Real experts!)
  5. Bruce Tuncks
    Oct 18, 2007
    698
    Aircraft:
    Jabiru SK, Libelle
    667
    Country:
    Country
    Hi Geoff, I happen to be in Melbourne this week, do those guys know about Jabiru regulators or are they just good at motorbike electrics? Or is there a better regulator from a motorbike ?
    regards, Bruce
  6. geoffreywh
    Nov 28, 2006
    793
    338
    Country:
    Country
    no, they are experts in regs. generally. They will know what to use, I believe they had their own made. I never had a failure from any of their bits in 20 years.
Share This Page
