1. Welcome to Recreational Flying, the Home of Recreational and GA Pilots, Aircraft and Aviation. Please register, it's FREE to use ALL our great features. Hi
Mandatory Rotax 912 Ad
Discussion in 'Engines and Props' started by DWB, Nov 19, 2011.
  1. DWB
    DWB Guest
    0
    Here is a link to check if your engine is affected by this AD.
    http://www.rotax-aircraft-engines.com/portaldata/5/dokus/d05094.pdf
    I was unable to download the one on the CASA website.
    Fortunately my engines serial # is not included & hopefully this will be the case for everyone here in Australia at least.
    Interesting that there may be the possibility of some financial support from Rotax. I would think a free crankshaft would be a good place to start...........
  2. Scotty 1
    Scotty 1 Active Member
    Oct 11, 2011
    183
    Aircraft:
    AAK Hornet STOL
    West of Kempsey
    162
    Country:
    Country
    Greetings all,
    As some of you may be aware, Rotax have yesterday released an Alert service bulletin in regards to a possible crack that could occur on some 912-914 series crankshafts.
    The engine serial numbers affected are listed in the Rotax service bulletin, however for some reason the EASA AD lists ALL 912 and 914 engines as being affected, this is not the case.
    For ease of looking, I have attached to this e mail an Excel file which lists ALL the engines affected by there serial number and also the official Rotax alert service bulletin.
    No engines sold by Bert Flood Imports are affected, however there may be some factory built aircraft, or engines supplied with overseas kits imported into Australia that may be affected, so I suggest that people check there engine serial number with the list attached.
    ALL the engines affected were built at Rotax during the period of October / November 2010
    We are aware of only 3 engines in our distribution area that are in fact affected by this service bulletin, and I will be contacting these people directly.
    If you require any further information, please do not hesitate to contact me.
    Best Regards
    Wal
    Bert Flood Imports Pty Ltd
    17 – 18 Chris Drive
    Lilydale Victoria 3140
    Australia
    Ph +61 3 9735 5655
    Fax +61 3 9735 5699
    Email wal@bertfloodimports.com.au
    I got this the other day, but still check I think
    Cheers scotty
  3. David Isaac
    David Isaac Well-Known Member
    Apr 6, 2009
    3,635
    Aircraft:
    Citabria, C180, C185, C206, Auster J1B, Javelin
    Central Coast NSW
    2,157
    Country:
    Country
    Well nice to be advised by the manufacturer, unlike others where you find out after the problems ocurr.
  4. Vev
    Vev Active Member
    Jan 13, 2008
    629
    Aircraft:
    Ercoupe, Brumby 610, Auster, Yak52
    Tyabb
    294
    Country:
    Country
    Hi Scotty,
    Nice to hear it may be low impact in Oz.
    We have 4 rotax powered Gazelles in our school and was wondering what the impact may be.
    Btw ... cant see the spread sheet you mentioned??
    Vev
  5. Scotty 1
    Oct 11, 2011
    183
    Aircraft:
    AAK Hornet STOL
    West of Kempsey
    162
    Country:
    Country
    Crankshaft S/N
    Engine S/N Engine Type
    40426 4410884 912 A2
    40424 4410885 912 A2
    40422 4410887 912 A3
    40463 4412984 912 F3
    40462 4412985 912 F3
    40236 4420965 914 F2
    40349 4420966 914 F2
    40478 4420967 914 F3
    40477 4420968 914 F3
    40469 4420969 914 F2
    40464 4420970 914 F2
    40432 4420972 914 F2
    40435 4420973 914 F2
    40436 4420974 914 F2
    40440 4420975 914 F2
    40438 4420976 914 F2
    40466 4420977 914 F2
    40439 4420978 914 F2
    40256 4924044 912 S3
    40257 4924045 912 S3
    40259 4924046 912 S3
    40264 4924047 912 S3
    40265 4924048 912 S3
    40267 4924049 912 S3
    40329 4924050 912 S2
    40337 4924051 912 S2
    40335 4924052 912 S3
    40310 4924053 912 S3
    40300 4924054 912 S2
    40302 4924056 912 S2
    40303 4924058 912 S2
    40461 4924064 912 S2
    40456 4924065 912 S2
    40455 4924066 912 S2
    40453 4924067 912 S2
    40450 4924068 912 S2
    40447 4924070 912 S3
    40446 4924071 912 S3
    40444 4924072 912 S3
    40443 4924073 912 S3
    40442 4924074 912 S3
    40441 4924075 912 S3
    40507 4924076 912 S3
    40480 4924077 912 S2
    40358 4924081 912 S2
    40359 4924082 912 S2
    40373 4924083 912 S3
    40488 4924084 912 S3
    40361 4924086 912 S3
    40298 6770159 912 UL2
    40294 6770160 912 UL2
    40293 6770161 912 UL2
    40323 6770162 912 UL2
    40319 6770163 912 UL2
    40460 6770164 912 UL2
    40459 6770165 912 UL2
    40458 6770166 912 UL2
    40457 6770167 912 UL2
    40454 6770168 912 UL2
    40452 6770169 912 UL2
    40451 6770170 912 UL2
    40448 6770171 912 UL2
    40479 6770172 912 UL2
    40476 6770173 912 UL2
    40475 6770174 912 UL2
    40474 6770175 912 UL2
    40473 6770176 912 UL2
    40366 6770184 912 UL2
    40304 6774151 914 UL-LB2
    40306 6774152 914 UL-LB2
    40301 6774153 914 UL-LB2
    40305 6774154 914 UL-LB2
    40299 6774155 914 UL-LB2
    40316 6774156 914 UL-LB2
    40309 6774157 914 UL-LB2
    40314 6774158 914 UL-LB2
    40308 6774159 914 UL-LB2
    40307 6774160 914 UL-LB2
    40295 6774165 914 UL-LB2
    40251 6774166 914 UL-LB2
    40325 6774168 914 UL-LB2
    40336 6774169 914 UL-LB2
    40333 6774170 914 UL-LB2
    40332 6774171 914 UL-LB2
    40315 6774176 914 UL2
    40339 6774177 914 UL2
    40340 6774178 914 UL2
    40342 6774179 914 UL2
    40343 6774180 914 UL2
    40345 6774181 914 UL2
    40346 6774182 914 UL2
    40347 6774183 914 UL2
    40250 6774184 914 UL-LB2
    40351 6774185 914 UL-LB2
    40296 6774186 914 UL-LB2
    40352 6774187 914 UL-LB2
    40312 6774188 914 UL-LB2
    40311 6774189 914 UL-LB2
    40326 6774190 914 UL-LB2
    40322 6774191 914 UL-LB2
    40327 6774192 914 UL-LB2
    40334 6774193 914 UL-LB2
    40421 6774199 914 UL-LB2
    40419 6774200 914 UL-LB2
    40417 6774201 914 UL-LB2
    40414 6774202 914 UL-LB2
    40418 6774203 914 UL-LB2
    40415 6774204 914 UL-LB2
    40413 6774205 914 UL-LB2
    40412 6774206 914 UL-LB2
    40408 6774207 914 UL-LB2
    40409 6774208 914 UL-LB2
    40472 6774209 914 UL2
    40468 6774210 914 UL2
    40471 6774211 914 UL2
    40467 6774212 914 UL2
    40470 6774213 914 UL2
    40246 6774220 914 UL-LB2
    40235 6777492 912 ULS2
    40233 6777493 912 ULS2
    40240 6777494 912 ULS2
    40239 6777495 912 ULS2
    40234 6777496 912 ULS2
    40244 6777497 912 ULS2
    40243 6777498 912 ULS2
    40237 6777499 912 ULS2
    40252 6777500 912 ULS2
    40247 6777501 912 ULS2
    40253 6777502 912 ULS2
    40255 6777503 912 ULS2
    40254 6777504 912 ULS2
    40249 6777505 912 ULS2
    40263 6777514 912 ULSFR2
    40331 6777526 912 ULS2
    40330 6777527 912 ULSFR2
    40321 6777528 912 ULS2
    40317 6777529 912 ULS2
    40313 6777530 912 ULS2
    40318 6777531 912 ULS2
    40338 6777532 912 ULS2
    40320 6777533 912 ULS2
    40341 6777534 912 ULS2
    40348 6777535 912 ULS2
    40344 6777536 912 ULS2
    40367 6777537 912 ULS2
    40324 6777538 912 ULS2
    40368 6777539 912 ULS2
    40369 6777540 912 ULS2
    40370 6777541 912 ULS2
    40371 6777542 912 ULS2
    40357 6777544 912 ULS2
    40360 6777545 912 ULS2
    40372 6777546 912 ULS2
    40363 6777547 912 ULS2
    40374 6777563 912 ULS2
    40365 6777564 912 ULS2
    40258 6777565 912 ULS2
    40260 6777566 912 ULS2
    40261 6777567 912 ULS2
    40262 6777568 912 ULS2
    40266 6777569 912 ULS2
    40297 6777576 912 ULS2
    40506 6777577 912 ULS2
    40505 6777578 912 ULS2
    40504 6777579 912 ULS2
    40500 6777580 912 ULS2
    40503 6777581 912 ULS2
    40501 6777582 912 ULS2
    40499 6777583 912 ULS2
    40498 6777584 912 ULS2
    40495 6777585 912 ULS2
    40491 6777586 912 ULS2
    40484 6777587 912 ULS2
    40490 6777588 912 ULS2
    40489 6777589 912 ULS2
    40487 6777590 912 ULS2
    40483 6777591 912 ULS2
    40482 6777592 912 ULS2
    40481 6777593 912 ULS2
    40497 6777594 912 ULS2
    40431 6777596 912 ULS2
    40427 6777609 912 ULS2
    40496 6777610 912 ULS2
    40350 6777624 912 ULS2
    40354 6777625 912 ULS2
    40353 6777626 912 ULS2
    40355 6777627 912 ULS2
    40356 6777628 912 ULS2
    40362 6777630 912 ULS2
    40364 6777631 912 ULS2
    40410 6777634 912 ULS2
    40411 6777635 912 ULS2
    40416 6777636 912 ULS2
    40420 6777637 912 ULS2
    40492 6777638 912 ULS2
    40425 6777639 912 ULS2
    40493 6777640 912 ULS2
    40494 6777641 912 ULS2
    40502 6777642 912 ULS2
    40328 6777667 912 ULS2
    40485 6777668 912 ULS2
    40465 6777686 912 ULS2
    40449 6777688 912 ULS2
    40437 6777689 912 ULS2
    40433 6777690 912 ULS2
    Vev This is the list of affected engines I got in the email sent on to me. Hope yours are not on the list and yes David it is good to see a bit of support from at least one mob.
    Cheers Scotty
  6. avi8tr
    avi8tr Guest
    0
    Are they running 4 Gazelles down there these days Vev? Must be picking up!
  7. Vev
    Vev Active Member
    Jan 13, 2008
    629
    Aircraft:
    Tyabb
    294
    Country:
    Country
    Thx Scotty,
    This list is very helpful.
    av8,
    Yes mate we are running 4 of them now and have a couple of C162 inbound as well ... RAA training is going great guns.
    Vev
Share This Page
