Thruster87 Posted January 30, 2009 Share Posted January 30, 2009 Recently in my inspections I have been seeing improper use of Nyloc nuts and bolts. AC 43-13 is very clear in that nyloc nuts should not be used on assemblies that rotate or high temperature areas. Important assemblies that rotate are the push rod ends in the flight control system, elevator, rudder and aileron hinges and any other rotating assemblies. These areas should have a drilled bolt and a casellated nut with a cotter pin. Cheers T87 Link to comment Share on other sites More sharing options...
Guest keeffe Posted January 30, 2009 Share Posted January 30, 2009 Hmm Think I better have a look at my drifter I have a few nylocks on the elevator etc. Link to comment Share on other sites More sharing options...
Guest ozzie Posted January 30, 2009 Share Posted January 30, 2009 Remember to check for at least three threads showing past the nut on all the other nylocs. Link to comment Share on other sites More sharing options...
Thruster87 Posted January 31, 2009 Author Share Posted January 31, 2009 Our chief LAME mentioned a while back that one of the bigger aircraft manufacturers in the USA now accepts flush but I still prefer at least 1 1/2 threads as min.Cheers T87 Link to comment Share on other sites More sharing options...
Ted Snook Posted February 1, 2009 Share Posted February 1, 2009 I used to be a DeHavilland apprentice, in the '50s, and we were taught 1.5 to 2.5 threads showing, and never use a Nyloc more than once. We should also remember that Nylocs are not class 1 locking - all vital fixings should be class 1. Examples of class 1 locking are peening, staking, (not often used on Microlights) wire locking and split pins or quick release pins and cotter pins, used in conjunction with castellated nuts. Occasionally where a class 1 locking method cannot be used, it may be necessary to use loctite in conjunction with a nyloc nut - prop nuts/bolts are an example of this, but there are others. Link to comment Share on other sites More sharing options...
Guest Baphomet Posted February 2, 2009 Share Posted February 2, 2009 nuts A much bigger concern to me, is the number of bolts in use with the wrong 'grip' length (unthreaded section). Link to comment Share on other sites More sharing options...
Guest ozzie Posted February 2, 2009 Share Posted February 2, 2009 This problem with the grip length may be caused because of using imperial hardware (US) on metric designed aircraft. the GA Trinidad and Tobago (french designed) use metic hardware. be aware of this when rebuilding/repairing European Aircraft. Link to comment Share on other sites More sharing options...
Dayble Posted February 2, 2009 Share Posted February 2, 2009 I am suprised that our Jab 230 has just a nyloc on the 1/8, single bolt, that holds on the front wheel - no pin. Is that common to other A/C too ? Link to comment Share on other sites More sharing options...
Guest Maj Millard Posted February 2, 2009 Share Posted February 2, 2009 The US standard, AC43.13 and all that, is minimum of one thread and maximum of three threads. More than three threads, you get a shorter bolt, or put a washer under the nut. Since we generally use AN hardware (Army/Navy, which is all they had back in 1930) , we should be prepared to abide by those standards, as they were developed and perfected over many years of practical testing. It's annoying when some one comes along, and for no good reason wants to reinvent the wheel. The AN standard wheel isn't broken, and doesn't need to be fixed, or modified. AN hardware has always worked for me, even on the occasions where I've manage to bend a bolt or two. If you have ever had the pleasure (sic) of working on a British aircraft such as the BN Islander, you would know what an absolute waste of time it is, when somebody thinks they know better, and depart from Standard AN hardware useage. Metric hardware is a whole different ballgame, however many Euro manufacturers still use the industry standard AN hardware. Link to comment Share on other sites More sharing options...
Thruster87 Posted February 3, 2009 Author Share Posted February 3, 2009 Talking about Jabs,these have the highest number of improper use of nylocs that I've come across Cheers T87 Link to comment Share on other sites More sharing options...
Guest bigblockford545 Posted February 4, 2009 Share Posted February 4, 2009 The three bolts that form the hinges for the flaps on both the jabby LSA and 120 use nylocks. Simon Link to comment Share on other sites More sharing options...
Guest ozzie Posted February 4, 2009 Share Posted February 4, 2009 Who exactly does the inspection and gives the CofA for factory built RAAus aircraft? the RAAus or CASA? just curious Link to comment Share on other sites More sharing options...
Guest ando79 Posted February 4, 2009 Share Posted February 4, 2009 tecnams have nylocs all over them, including flight controls! Link to comment Share on other sites More sharing options...
Guest pelorus32 Posted February 4, 2009 Share Posted February 4, 2009 Who exactly does the inspection and gives the CofA for factory built RAAus aircraft? the RAAus or CASA? just curious Good Question. RAAus a/c that are not LSA do not have a CofA. They need to be of an approved type and registered with RAAus. LSA a/c if factory built are entitled to a S-LSA CofA which is issued by a CASA delegate. Regards Mike Link to comment Share on other sites More sharing options...
djpacro Posted February 4, 2009 Share Posted February 4, 2009 You might find that the Tecnam and Jabiru follow standard industry practice. DO NOT use self-locking nuts on parts subject to rotation .. They may be used with anti-friction bearings and control pulleys, provided the inner race of the bearing is secured to the supporting structure by the nut and bolt. You should find that the nut is not used on a part subject to rotation. i.e. no movement between the nut and the part it is snug against.My copy of the AN spec (in my 40 year old copy of the Aircraft Mechanic's Pocket Manual) states "end of bolts or screws must extend at least the full round or chamfer thru the net" from which came the standard practice of at least one and not more than three threads extending thru the nut. I've seen more failures and lucky people associated with castle nuts and missing split pins in control systems than with nylocs. All of the certified factory-built aeroplanes that I fly have nylocs throughout the flight control system plus a few castle nuts where required. Link to comment Share on other sites More sharing options...
Guest ozzie Posted February 4, 2009 Share Posted February 4, 2009 Major, just to update the AN prefix. The Army standard has been replaced by the Air Force standard. Still AN tho'. Just some general information as to how 'standards' came about. Uniform standards are by necessity an evolutionary process. In the beginning each military service came to it's own standards the Army Air Corps had AC standards the Navy had NAF, Naval Aircraft Factory, as time went on they combined into the AN standards. With the introduction of turbines and high speed these in turn became the Air Force/Navy and NAS, National Aerospace Standards, futher down the track these were consolidated into MS, Military Standards designation. so today we have 3 common standards AN MS and NAS. I rely on two reference books either one i would recommend, Standard Aircraft Handbook for mechanics and technicians by Larry Reithmaier, now in it's six edition, and the Aviation Mechanic Handbook by Dale Crane, now in it's fifth edition. Both of these reference manuals are referred to as 'bibles' by aircraft repairmen. If you build or maintain your aircraft you should have one or both for reference. Cheers ozzie Link to comment Share on other sites More sharing options...
Yenn Posted February 4, 2009 Share Posted February 4, 2009 "I am suprised that our Jab 230 has just a nyloc on the 1/8, single bolt," Could that be an AN bolt? I have never seen less than AN3 which is 3/16" Not being a Jab owner I cannot be sure but I doubt that a 1/8" bolt would be used for anything structural. Link to comment Share on other sites More sharing options...
Guest ozzie Posted February 4, 2009 Share Posted February 4, 2009 what are the markings on the bolt head? the smallest AN bolt listed is AN3 (3/8 diameter.) Not to say that there are smaller sizes. i do not have a full cataloge Link to comment Share on other sites More sharing options...
djpacro Posted February 4, 2009 Share Posted February 4, 2009 Some useful reading: AC 23.607-1 Self-Locking Nuts on Bolts Subject to Rotation Link to comment Share on other sites More sharing options...
