My BMW R1150 conversions
fly_tornado
One of my other projects is to build an aircraft engine out of a BMW bike engine.
This idea spawned from the german company takeoff which does a lot of these conversions in the EU. This is going to be a pusher setup for my Tornado using an Ivoprop. I have RT engine with 8000miles from a cop bike and RS motor with 24000 miles.
The BMW engine is a good choice for a aero conversion, its a well engineered engine compared to most auto conversions, everything in it is extremely well made, the photos don't convey the feeling of quality in all the components.
95HP @ 7250 rpm
100NM @ 5500 rpm
2.5:1 gearbox
vibration isolator in the gearbox
35% air cooled and 65% oil cooled
engine has 2 oil systems with one dedicated to cooling the engine
less than 80KGs ready to fly
ECU with 2 ignition systems
I have started placing things in there positions working out how to fit it all together...
  • Replies 145
To get it flying my to do list includes:
Hack up the wiring harness (this is a big job as the BMW wiring harness is massive and links everything together in 1 harness) The wiring harness sits ontop of the engine on the bike but it will end up underneath it in the plane.
Build engine mounts, the engine is designed as a stressed member of the bike, so the holes already exist.
Build oil cooler mounts and add an additional cooler.
Build a fuel system, it requires a high pressure system with a fuel return from the regulator. On the bike the tank is above the engine and the plane will have the tank underneath it.
Build an exhaust extension/adapter and muffler and exhaust mounts.
Wire it into the existing aircraft electrical system to include a ECU reset function
Install a bigger battery.
I think these engines have been used in the USA before, or maybe earlier models. Another bike engine used was the Honda Goldwing engine, they kept the gearbox, using 2nd gear as a reduction drive.
  • Helpful 1
The older r100s where used prior to the 1100/1150 engines coming on the market, they needed a lot of mechanical work to get them to perform as well as a 1100.
I wouldn't use a leadwing engine in a plane they would be much too heavy and a 6 cylinder will be more expensive to service.
the porsche designed one wouldn't be too bad. A while back I saw an ad on from a guy selling an RE drive to suit a harley engine, clicked on his "other items" link and he had a complete engine less case and rods, selling due to breaking a rod.
Don.
I saw both in old versions of Kitplanes around the same time. Sadly I lent some of my old mags and they havn't all come back, so I can't refer to the dates. The Honda was used I think in a Nieuport as was the BMW.
  • 4 years later...
Yes FT,
Where are you on this?
I have many years experience two wheel flying with BMW Bikes are they are fantastic. Extreme quality compared to anything on two wheels. If you keep fresh oil and fuel then almost impossible to break.
A terrific engine and probably the best engine in the world reliability wise for conversion to aircraft duty.
Remember the BMW logo (roundel) is a spinning prop against a blue sky. They started making aero engines first.
Teutonic efficiency. This is why so many asian car engines are quite good, it's the German engineers they used to design them. . .
I hope that the engine doesn't use the same ecu firmware as VW, or the greenies will be all over you about your emissions. ( No, not the ones on the forum )
A bloke from our field had a Thruster TST with a BMW 600cc engine, R60 ? I don't know much about these engines, my Brother Ray still has a K100 (1,000cc ) ex cop bike, so I am assuming that the R60 is 600. . .?
Iit did fly, but the thing was just too heavy really, and could only be flown single seat. On throttle reduction the descent rate was alarming. ( His words, but I saw it fly and I Agree )
It crashed in Scotland about fifteen years ago following undercart damage during a heavy landing and was not rebuilt. I have no idea on the technical specs, ie reduction drive, prop used etc. . . as I said, never owned a Beemer Bike.
I'm not familiar with the "Tornado" airframe though,. . . got any pictures ?
Hope the project works well anyway cobber, it looks / sounds good so far.
Phil
There are lots flying OS, particularly in Europe...they tend to be the older ones about
Check this page out, you will need to use google translate
https://translate.google.com.au/translate?hl=en&sl=de&u=http://www.takeoff-ul.de/&prev=search
go to the page titled Drieachser and then progress through the sub pages using the little 1 2 3 4 icons below the picture... makes for interesting reading
ok so life got in the way since I started my build, I had a change of business in 2011 that sucked up all my cash for the last 4 years.
There have been a few issues along the way...
I picked up 2 tornado out of the states and landed them in mid 2010, there where flying but they needed major refurbishment. When I first got them I noticed the wiring was a bit sub-standard and as I went through that I noticed the paint was peeling on the frames and the frames were rusting. The are very early models, a '92 and a '94 and neither of the frames been rust treated properly since new, subsequent owner had just painted over the rust, the 92 has 5 layers in places. So I stripped the 92 to pieces and taken back to bare metal. This is a long and tedious process because as I go along I find more and more bodged up fixes.
The other issues I am working on
The biggest issue is the Tornado was a copy of the Earthstar Thundergull JT2. Both of which was designed around the Rotax 503 and the 582. The problem for getting the BMW into the Tornado is the BMW's lack of lower front engine mount to use in a bed style motor mount. There is a small mount on the block used to hold the engine during maintenance but I'm not 100% confident that it won't crack the block in regular use. The BMW is popular in trikes and tractors because they have a vertical engine mounting, which the BMW is perfect for as it has multiple mounts above and below the engine. Building that front engine mount is tricky as the pipes snake around the front of the
The next issue is the weight and balance, because the tornado has been designed around the lightweight 2stroke engine the big lump of alloy behind the balance point means it needs some weight in the nose. Later model Tornados have the battery mounted in front of the front wheel which means fabricating a battery box and reworking the wiring harness. The other option is to move the pilot seat forward.
I might have to do both.
There are some more minor issues, like the wiring harness, with BMW you get 1 wiring harness that covers the entire bike. Its as thick as a 50cent piece in places. I have managed to cut out a lot of stuff but a lot of the switches disable the ECU, sidestand, clutch and gear shifter combos is one example. The engines will need a prop extension... brb
Yes FT,Where are you on this?
I've been interested in them but warned off by someone who has seen a number of conversions. Apparently they're OK if you're a mechanical genius and can spend hours tinkering. I'm not.
  • 2 months later...
I read somewhere that as stated above the Logo is indeed the Bavarian flag but the spinning prop myth happened and that as BMW did indeed build acft engines it was a myth they help to propagate.
I think the Virago motored Nieuport crashed. early in it's career. Goldwing motors come in 4 and six cylinder . The six would be potentially one of the smoothest aero engines you might use. Flat sixes are much smoother that fours or twins. Nev
