DrZoos Posted December 9, 2013 Share Posted December 9, 2013 I received today in the mail a booklet from CASA about aviation Safety.. Its pretty much a self promotion about CASA and how wonderful they are, how much the listen etc etc etc But of interest was a section on the top 10 identified deficiencies for ramp checks and i thought some might be interested... 1. Not carrying current licences and medical cert not current 2. No navigation / fuel log 3. Have not accessed weather / Notam 4. Do not comply with flight time limitations 5. Charts not carried or not current 6. EFB if used not appropriate 7. Maint releases not in order 8.Flight manual / checklist not up to date 9. No evidence of weight and balance 10. Required serviceable, accessible emergency equipment not on board 1 Link to comment Share on other sites More sharing options...
Old Koreelah Posted December 9, 2013 Share Posted December 9, 2013 Thanks for that, Doc. A few of those apply to RA aircraft. Link to comment Share on other sites More sharing options...
storchy neil Posted December 12, 2013 Share Posted December 12, 2013 I would have though all would have applied to RA aircraft but thats just me neil 1 Link to comment Share on other sites More sharing options...
Old Koreelah Posted December 12, 2013 Share Posted December 12, 2013 Does a RA pilot flying a home-built have to carry a Medical cert, maint. release, manual, w&b? 1 Link to comment Share on other sites More sharing options...
djpacro Posted December 12, 2013 Share Posted December 12, 2013 There are a few which do not apply to private operations not associated with an AOC. Link to comment Share on other sites More sharing options...
storchy neil Posted December 12, 2013 Share Posted December 12, 2013 djpacro witch ones neil carry a Medical cert, maint. release, manual, w&b?proof of yes Link to comment Share on other sites More sharing options...
Old Koreelah Posted December 13, 2013 Share Posted December 13, 2013 Is carrying a flight manual mandatory in RA aircraft? If the manufacturer provided none? If flying a 19-reg aircraft of your own design? Experimental? Just how much paperwork has to be carried in a rag and tube open aircraft? Link to comment Share on other sites More sharing options...
cscotthendry Posted December 13, 2013 Share Posted December 13, 2013 For 19 reg aircraft, what maint release? Medical certificate? We don't get those for RAA, Do we? I've never been asked for one by ANY instructor... Link to comment Share on other sites More sharing options...
Guest ozzie Posted December 13, 2013 Share Posted December 13, 2013 Your raa memberships card is your medical. You signed and had witnessed that bit of paper when you renewed. Link to comment Share on other sites More sharing options...
DrZoos Posted December 13, 2013 Author Share Posted December 13, 2013 Is carrying a flight manual mandatory in RA aircraft?If the manufacturer provided none? If flying a 19-reg aircraft of your own design? Experimental? Just how much paperwork has to be carried in a rag and tube open aircraft? Just tell them when you took off it was beside you.... Link to comment Share on other sites More sharing options...
DrZoos Posted December 13, 2013 Author Share Posted December 13, 2013 Maint release - I think http://www.recreationalflying.com/threads/aus-raa-maintenance-record-sheet.36795/ Whats the requirement for this medical ? Is this just a clearance after you have had a problem? http://www.raa.asn.au/wp-content/uploads/2012/02/Medical-Questionnaire-and-Examination-Form-revised-1-8-2013.pdf Link to comment Share on other sites More sharing options...
facthunter Posted December 13, 2013 Share Posted December 13, 2013 I (one) roll of soft tissue should be enough. Once it equals the weight of the plane you just about have it, otherwise. You need the planes card ( current) your current RAAus certificate. W&B calcs. This can be very simple but needed officially. There is no maintenance release (yet) GA must carry current medical. Usual weather and planning stuff for us too. Nev Link to comment Share on other sites More sharing options...
djpacro Posted December 13, 2013 Share Posted December 13, 2013 djpacro witch ones neilcarry a Medical cert, maint. release, manual, w&b?proof of yes For a start, there is no rule requiring proof of W&B to be carried in the aeroplane. 1 Link to comment Share on other sites More sharing options...
facthunter Posted December 13, 2013 Share Posted December 13, 2013 I wouldn't normally doubt you, but I always believed otherwise. I can't recall when I didn't have one. It's related to all your performance and trim and power settings. The last thing to come on board is the load sheet correction.. Nev Link to comment Share on other sites More sharing options...
djpacro Posted December 13, 2013 Share Posted December 13, 2013 My comment related to private ops not associated with an AOC. Likewise: 4. Do not comply with flight time limitations (- unless flying commercially otherwise) 6. EFB if used not appropriate If there is no rule or a rule is not applicable to "our"operations then there is no legal requirement - beyond that we may discuss recommendations. Link to comment Share on other sites More sharing options...
facthunter Posted December 13, 2013 Share Posted December 13, 2013 By being required to operate within the design parameters, a demonstration of compliance on a ramp check would be a reasonable request to be documented or explained. Some aircraft cannot be loaded outside the balance limits while they comply with weight limitations, but other aircraft such as a drifter require a minimum weight for front seat, as an example. The operating pilot should be able to demonstrate this required knowledge to safely operate the aircraft relating to balance. Nev 1 Link to comment Share on other sites More sharing options...
DrZoos Posted December 13, 2013 Author Share Posted December 13, 2013 I suspect they must login to the backend of NAIPS and can see when you have accessed it. How else do they know you havent accessed it. And when you do go in the report says who it is served to. .... Because if they asked me or anyone else had they accessed it and they forgot, im sure they would say yes. And when they say what did it say..... Sorry sir your investigation has stressed me to the point I have short term memory loss......a bit like Alan Bond and others Link to comment Share on other sites More sharing options...
Gnarly Gnu Posted December 13, 2013 Share Posted December 13, 2013 Yes, that's why Airservices require you to log in and of course to do this you have supplied your details with associated ARN. Link to comment Share on other sites More sharing options...
greybeard Posted December 13, 2013 Share Posted December 13, 2013 what's the problem with not only doing some preflight planning but being able to prove that you've done it? you've either done the good airmanship thing or you haven't. 4 Link to comment Share on other sites More sharing options...
facthunter Posted December 13, 2013 Share Posted December 13, 2013 I think you are on the ball there Greybeard. It is about airmanship. Do the preparation and planning ant the outcome will be much better. Ramp checks can be a bit academic depending on the practical approach of the persons involved. With people of substance and experience you should get on well. If you encounter someone who is just pedantic, it is a bad day.. Nev Link to comment Share on other sites More sharing options...
ben87r Posted December 13, 2013 Share Posted December 13, 2013 + 1 for the no W+B required in the AC. Cant honestly think of once Ive taken it although it has been done for most flights, cant say all tho, if ive known Im flying the same AC with the same weights ive left it 1 Link to comment Share on other sites More sharing options...
