    Register Log in
Sign in to follow this
Lyndon
Lyndons Savannah VG Thread
Honestly every person who has built a kit (including myself) has sworn there's something missing, only, embarassingly, to find it later on down the track.
Here here been there done that swearing blind I was missing stuff....the only thing I had and most others had was just not enough rivets supplied but there are all the rivets inc the countersunk type..you just cant see them yet
I have yet to use a a 5 flush rivet do the kits must use very few. Seeing I haven't seen one yet
Yes, just a small plastic bag full, maybe less than 100. Usually in the same box all tha A4 rivets came in.
I did get short of countersunk rivets and found that by drilling 5/32" through a block of steel then drilling part way through with a larger drill I had a die to hammer regular rivets into with a dolly to make them counter sunk for the last few. They did need a rub around the edges on the grinder to take the frilly bits off.
  • Helpful 1
Rivet advice. I have bought some longer a4 rivets. They are plain without the center grab section. See left rivet. Kit a4 is in the middle and kit a5 on the right. I have asked one person who said they Will be fine. But before I get riveting I need a hug and someone else to tell me these are fine to use on my aircraft. ??? Thoughts
Thanks Lyndon
Thanks Lyndon
No hugs here.
Where are you intending to use them?
They are next to useless. Pull a couple and you will see what I mean. They pull up like macaroni noodles. Make sure and get "multi-grip" rivets next time.
I agree with Rank, useless. That area cops a lot of stress in a hard landing situation. Better use the spec rivets or A5 instead.
Yes, why risk it. Do you think Reg from Aerokits will have a bunch of proper rivets? Maybe he can courier you some and you'll have it by Wednesday or Thursday.
He has boxes of everything over there. Only way to find out is ask him!
No mean feat getting those rivets in Adelaide. But I found a place. Now my car has decided to play up. Next week onto it again more rivets.
Lyndon
No mean feat getting those rivets in Adelaide. But I found a place. Now my car has decided to play up. Next week onto it again more rivets.Lyndon
Buy a few extra rivets and you can use it to tighten that loose guard on the car too.
Skid a bit ordinary. I'm sure this correct but it's a little agricultural.
Lyndon
You're not going to put a micro tail wheel on your Savannah, just like the Foxbat/A22/Valor?
I'm running my trim wiring in the fuse prior to final riveting. I'm thinking it comes out the top of the top skin under the the little cover that is front of the fin. I have some dimensions but no instructions. From there I will run it to the battery ??
Lyndon
Lyndon
No, run it down the left side of the fuse, under the left seat, up the left side of the cabin footwell, to the back left side or the instrument panel where it should joyfully meet with the trim switch and indicator.
On the floor ??? Main concern is it comes out through the hole in the top skin where an elevator cable comes out. What to get my length right
just have it 50mm or so out the top of the fuse at the back to connect to the cable coming out of the stab, run it (through grommets in the fuse frames) sort of diagonally a bit till you get to the bottom. Make sure you have it the right way round or you will be swearing alot later.
  • Helpful 1
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
