Links & Service bulletins
Red
Please post any Links you have in this thread and I'll add them to the list
Ta, Red
Aerofix
Jabiru Owners
[email protected] | Topics
Service Bulletins
https://jabiru.net.au/wp-content/uploads/2019/07/JSL023-1_Jabiru-Engine-Overhauling-Build-Issues.pdf
https://jabiru.net.au/wp-content/uploads/2019/02/JSB014-3_Propeller_Installation_Maintenance.pdf
https://jabiru.net.au/wp-content/uploads/2019/02/JSL022-1_Fuel_pump_drain.pdf
https://jabiru.net.au/wp-content/uploads/2019/02/JSB012-5_Flywheel_Screws.pdf
https://jabiru.net.au/wp-content/uploads/2019/01/JSB040-2-Jabiru_-Mechanical-Fuel-Pump.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSB004-4_Oil_Pump-Cooler.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSB005-2_Early_6Cyl_Muffler.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSL014-5_Jabiru_Cylinder_Head_Inspection_DRAFT_.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSL008-2_Valve_Spring_Washer_wear.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSL007-7_Fuel_Guidance.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSL018-1_Oil_Cooler_Hoses.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSL017-1_Pattern_Parts.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSB031-3_Through_Bolt_Replacement_and_Upgrade.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSL015-1_Rotor_Button.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSL010-1_Service_intervals.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSB018-3_Jabiru_Engine_Tuning.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JBS022-2.pdf <propellor flange attachment
https://jabiru.net.au/wp-content/uploads/2018/05/JSL009-1_Starter_Solenoid.pdf
https://jabiru.net.au/wp-content/uploads/2018/11/JSB033-2_Piston_Circlips.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSB021-1.pdf <configuration update
https://jabiru.net.au/wp-content/uploads/2018/05/Starter-Motor-earth-Cable_JSL005-1.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/Dip-Sticks-8A035A0D-1.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSB010-3.pdf <statement of compliance to ASTM LSA
https://jabiru.net.au/wp-content/uploads/2018/05/JSL004-1-Engine-Cooling.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSL002-3cancel-letter.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/Engine-Cooling-JSB016-1.pdf
https://jabiru.net.au/wp-content/uploads/2018/05/JSB013-1.pdf <engine rocker chamber vent
https://jabiru.net.au/wp-content/uploads/2018/05/Revised_Jabiru_Engine_TBO.pdf
