Garfly Posted June 15, 2022 Share Posted June 15, 2022 (edited) Interesting that OzRunways were able to incorporate the frequency changes in AIP SUP H50/22 (Ballina MBA/SFIS) on their version of the charts whilst the feds missed the deadline for their own new document releases. s22-H50.pdf From OzRWYs email circular: Meanwhile, there's a spirited discussion re the new arrangements on pprune https://www.pprune.org/australia-new-zealand-pacific/647146-casa-government-mates-invent-new-airspace-classification.html As one contributor puts it: 0th Jun 2022, 00:51 #5 (permalink) 43Inches Join Date: Oct 2007 Location: Aus Posts: 1,548 It's not just in Australia, the FAA is still trying to nut out the problems with high traffic CTAFs such as in Alaska, where there have been multiple mid air collisions. So far the only thing working is when all aircraft have some form of ACAS/TCAS fitted, yet all agencies seem so reluctant to mandate working transponders in these areas. The last major collision was between aircraft where both had ACAS, but one had it switched off. Yes ADSB can be swamped but the system tends to prioritise close contacts so that means that unless you have 18+ aircraft within 5 miles it should still work fine. Class D can not work in the Ballina area, its way too complex to efficiently operate a tower there and blocking out airspace for CTA will then condense the VFR private traffic even further creating more risks for them. Move into the 21st century guys, get transponders, use them and its all good. As for separation standards in class G, don't collide, sounds great, but TCAS applies a bubble around those fitted so when you sneeze close to each other you get an RA and that's a mandatory report to be investigated. 11th Jun 2022, 02:05 #11 (permalink) 43Inches Join Date: Oct 2007 Location: Aus Posts: 1,548 Quote: Originally Posted by Geoff Fairless Alphacentauri - you think Airservices "agreed" to SFIS, about which you are surprised. I took part in preliminary Zoom meetings with Airservices and can assure you that they invented it, CASA is simply their echo chamber when it comes to airspace. Various royal commissions into other aspects of government refer to this as "regulatory capture". I also totally agree with your comment about Airservices business model. 43 Inches - I agree that eventually "ATC" might devolve to separation based on "sense and avoid". However, I also believe that this concept is much further in the future than we are being led to believe by the driverless car industry and the driverless drone industry. The question I am posing is what do we do in the meantime? The point of this thread is that ICAO provides rules and procedures that member nations have signed up to, they include the airspace categorisation. The Minister is allowing CASA and Airservices to ignore those rules and procedures and invent a hybrid which may or may not work. (I am also pretty sure the Minister would not understand the nuances) Airservices claims to have written a safety case around SFIS, but has refused to release the document. CASA OAR wrote a report about Mangalore which apparently decided SFIS would not work. I say apparently because the report was removed from the CASA web site almost as soon as it was posted. No doubt at the behest of Airservices. The very essence of a safety case is that it should be public (not to mention how a publicly owned government agency is allowed to have secrets!). So my only conclusion has to be that it contains conclusions that SFIS created either a Class A (unacceptable) or Class B (can only be accepted by a General Manager) risk that is being withheld from the flying public. ICAO tells us that we can choose Class G, E or D (C, B and A are not necessary). In my opinion, a Class D Tower with enhanced low level surveillance would provide acceptable safety. You also assert that "Class D can not work in the Ballina area, it's way too complex to efficiently operate a tower there and blocking out airspace for CTA will then condense the VFR private traffic even further creating more risks for them." I'm not sure whether you are an air traffic controller or pilot, but I can assure you that I have seen Class D operations in far busier environments than Ballina, and they work just fine. ATC facilities need to be concentrated where they will have the most safety effect, statistically this will be around runways where there is "competition" for the airspace caused by speed and other performance differentials. Classically, a Control Tower resolves these issues by knowing pilot intentions, and aircraft performance, in order to ensure that pilots, IFR or VFR, are in the right place and the right order to operate the aerodrome safely and efficiently. The fact that other pilots may avoid the airspace only serves to remove flights from the terminal airspace that do not need to be there. This removes the "way too complex" you refer to and is in use all over the world. The problem is not that class D won't work AT Ballina, but the problem is the multiple close CTAFs causing this problem and the traffic between them. If this was a simple case of one airport that is saturated by its own traffic that would be a simple answer of, yes, a class D is required to sort it out. However, as it is, Ballina and Lismore traffic already have IFR approach conflicts and then there's all the private traffic between several ports. Hence why I say this has more in common with the issue in Alaska than any other place in Australia, lots of CTAFs in close proximity all with their own traffic blasting randomly in all directions. In regard to ACAS/TCAS, this is nothing new to aviation. I'm not at all saying the aircraft takes over and flies, it is a system that first of all alerts a pilot to other aircraft in proximity, and then some will direct a course to avoid. Being alerted that something is near you is all that is required, with almost all giving you some picture of where it is. Radio alerts are vague and prone to communication error, both in what is said, overtransmits blocking information and lastly interpretation and understanding there is a conflict, let alone being unfamiliar with local terms a local may use, fine in light traffic, ask for clarification, in heavy traffic another conflict will come up while you clear up your ambiguities. A device in the cockpit that says something is close, and look out, is much easier for all to understand and the required technology has existed for 30 years. TCAS/ACAS are a last line of defense, this is after you have communicated via radio and looked out the window to see and avoid. Talking is fine when you have 2-3 aircraft communicating, several aircraft in a similar location will just turn into a squeal of noise. Class D is not a quick fix, it requires infrastructure and provision of trained controllers, plus fields like Lismore will be severely impacted by the airspace, let alone the large amount of through traffic as Sunfish points out. Lastly a PA-28 almost collided with an ATR in Albury Class D airspace when there was pretty much no other aircraft in the area. This line from the report "The crew of the ATR were aware that there was traffic in the area but did not assess the position of the PA-28, in relation to their aircraft until activation of the TCAS TA". So Controlled airspace, Class D, radio communication, three parties aware of traffic, and TCAS most likely saved the day. Last edited by 43Inches; 11th Jun 2022 at 02:25. Edited June 15, 2022 by Garfly 1 Link to comment Share on other sites More sharing options...
Garfly Posted June 15, 2022 Author Share Posted June 15, 2022 BTW, here's the final ATSB report of the PA28 / ATR72 airprox mentioned above. Near collision between Piper PA-28, VH-XDI and ATR72, VH-FVR Albury Airport, New South Wales, on 19 October 2019 ao-2019-066_final.pdf From the report (published in Nov. 2020): "What's been done as a result // ... Virgin Australia and Airservices Australia have begun discussions to convene a cross industry stakeholder meeting to include operators, Civil Aviation Safety Authority, ATSB and the broader industry to discuss the ongoing risk to operations at non-controlled and airports in Class D airspace. " 1 Link to comment Share on other sites More sharing options...
pmccarthy Posted June 15, 2022 Share Posted June 15, 2022 I flew into Albury for the first time recently and could easily have made the same mistake. Link to comment Share on other sites More sharing options...
