    Register Log in
Tucano
Rotax Sodium Exhaust Valves
Is any one with a 914 interested in a set of Sodium Valves to suit their engine?  Rotax is recommending that the valves be changed at overhaul but I am sure non one could afford them - try and get a price.
I have made contact with a manufacturer engine valves that has Rotax blanks for sodium valves and based on a quote about 18 months ago a order for 24 would be  $1K for four.
Standard Rotax exhaust vales are about $US300 each so the price in good.
I will fun the purchase with a deposit of 30% non refundable if order is cancelled. Would need 3 buyers outside myself
Credits card is OK.
Sodium is not what they are made of . It's in the hollow valve stems and in liquid form shakes around and gets more heat out of the valve head.   The hollow stems are reduced in strength consequentially, making  them a "lifed" component and inescapably expensive, due to the design. Nev
Sodium-cooled valves are an expensive cure for short valve life. Stellite valves are a more affordable, and nearly as durable, option. Sodium-cooled valves do have a slight advantage as regards lightness, for very high RPM operation.
Rotax is using these in the 915 and based on my info its for the 2000 hours - that enough life for anyone. These are only for someone operating a boosted engine looking for improved combustion cooling, a 80hp 912 does not need them.
If am rebuild any engine at 2000 hours, the exhaust valves are for the bin, replacements are $1500 US plus, they can just do four for $800 euro and that is cheaper than Rotax plain exhaust valves.
So again asking
Posted (edited)
Keeping the valve head below a certain temp may be an issue also with the boosted engine.  As is always the case., extra heat must be dissipated.  They would not do it if it wasn't necessary. Nev
Edited by facthunter
more
We have 43'' available at take off with the supercharger - never been a issue to date
Ouch,
My old Alfas rang sodium exhaust valves, never ever heard of them having a issue.
The price could be worse.
My mate who builds Old school BMW M5 engines they are $ 400 each and you need 12, so $4800 just for exhaust side. And they are only going to get dearer.
7 hours ago, Kyle Communications said:
Mick are you saying I maybe a bit pedantic at times 😎:roflmao:
I was actually referring to the whole thread. :wave:
I have seen it many times here and elsewhere....Someone asks a question, fifteen pages later, the question remains unanswered, but the OP's motive, viability, knowledge, and who knows what else have been questioned or derided.
Edited by M61A1
Experience has shown that the stock radiator will handle the load especially when installed with a duct - air dose not want to go through a Rotax radiator just because its hung in the breeze.  My aircraft will also have the head load from the oil cooler added and the basic [very] calc's indicate it will be close to its limit at climb.
Therefore a valve that better transfer heat into the head from the valve may help but is not a deal breaker.
Hence the question at the start
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
