    Register Log in
rhtrudder
Power line markers
Anyone had a go at putting those orange balls on power lines , what’s involved, cost, I’m with powercor and a bit terrified what they will charge , the balls cost $600 for three,
49 minutes ago, Old Koreelah said:
An old pair of gym boots laced together are cheaper- and reflective.
As long as you have the 'gear' you'll be OK. But watch out for crackheads passed out on the runway.
How high AGL are the wires? You can buy those RotaMark rotating ones for around $160 each, and they can be installed from ground level with a hotstick, so any L2 ASP should be able to do it for you for their hourly rate.
Looks about 12 meters, could stand on top of a cattle truck and get a lot closer, what’s a L2 ASP , who sells the rotamark, do they clamp around the wires
A L2 ASP is a Level 2 Accredited Service Provider - basically a Sparkie who can work on the network infrastructure, as opposed to simple electrical stuff inside your house. You can buy them (the markers, not Sparkies ?) from the link in my previous post, or probably the manufacturer directly, and yes, they simply clamp around the wires.
Don't stand too high on the back of a high cattle truck - treat HT powerlines with the great respect they deserve. HT current can jump huge distances, and you need to keep at least 4 metres away from powerlines up to 33kV and 6 metres away from 66kV and above.
Know of at least one bloke who got fried by resting his hand on a semi-trailer tipper body, as he guided the truck driver lifting the tip body under 132kV HT powerlines.
Thought he could get within a metre and half of the HT powerline safely, but when the tip body got to 2M away from the HT powerline, the current arced to the tipper body, and the bloke resting his hand on the body provided the route to Earth. He survived, but not without serious burns.
Cost me $2400 total to get 3 on my powerline going across the southern end of my 2 strips. I got 2 on one strip and 1 of the other. Bloody robbers. It was Ergon where I am. I used to work for SEQEB now called Energex. And yes they charged me 600 for the 3 plastic balls as well at the time but that was about 5 years ago now. $1900 to fit. Mine is a SWER line
Looks like the way to go , thanks for that, l know a few sparkies hopefully one can do it, do they use the same rod  to replace the fuses on the pole
Only Ergon could fit the balls. They use a live line cherry picker to do it. The SWER line is 11kv.  Those spinner ones I saw for the first time only a week or two ago. They have them on the LV at Archer Falls. I can ask Doug Field who put them up but usually certainly up here in gods own country (QLD ? ) you can just work on the network it all has to be done via the control rooms.
 LV  415V 3 phase... but most likely 2 phase plus neutral if it feeds the Dairy
3 wires only it would be 11KV and then it goes to a transformer which drops it down to 415v 3 phase or 2 phase. You can usually tell by the size of the insulators
Edited by Kyle Communications
May be a stupid suggestion, but couldn't you lower something reflective on it by drone?  If it had a long enough rope you could stay 10m above it.
I have heard (second hand) that the power company in WA may supply them free and fit them when a service crew is in the area. Not sure about your state but worth a try?
You cant just hang something on a network powerline without permission or risk assessment etc..with all the proper bullsh#t you have to go through now days. If its your own property line then of course no drama
Found a electrician that can do it , only trouble he is in NSW , over the river, Moama, and can’t work in VIC, but is going to try figure something out hopefully
