Neil_S
Everything posted by Neil_S
  1. Hi Brendan, I wouldn't worry about it. My first plane, which I flew for about 5 years, was right hand on throttle, left on stick, but my current one is the opposite. It took very little time to get used to it (and I am in my sixties!) In fact as I drive a manual car I find it takes longer to get used to driving an automatic - my left foot nearly punches a hole in the floor! Cheers, Neil
  2. Yep - when I lived in the UK I remember at the timber yard buying 2 metres of 4" by 2" wood, and buying petrol in litres while distances were still in miles, and roadsigns in miles per hour......
  3. Hi, I was talking to a mate yesterday who flies a 160, and does aircraft maintenance himself - he said there are about 6 Rotax-powered Jabs around that he is aware of. If you want I can send you his number in a PM. Also try contacting Lethbridge airport and ask them for the number of a guy called Robert who has a Rotax-powered Jab. I've spoken to him in the past and I'm sure he can supply confirmation of several year's worth of safe operation. Cheers, Neil
  4. I would agree. They do look similar, but there is a different shaped fin/rudder, and different strut(s). You can see the word "Cessna" on the tail of one of the 140s too. In addition many Luscombe aircraft have the Luscombe "S" logo, which the aircraft in the picture has on its tail. I was interested to see it was 24 registered, implying factory-built. Neil
  5. Hi Nev, I think the Fisher is owned by Derek Dyer (it used to be anyway - it was previously painted green, if I recall correctly). Cheers, Neil
  6. Hi Nev, It's a 1930's Curtiss Robin, owned by Jack Vevers at Tyabb. Immaculate! Cheers, Neil
  7. Hi folks, I really enjoyed this fly-in and thought I would add a few pictures for you all. Cheers, Neil
  8. And if you use AVPlan (and probably OzRunways) the screen will show both local time and UTC. It's really not that hard. Cheers, Neil
  9. Love them! Thanks for posting. Cheers, Neil
  10. Hi IBob, I find the same on my Savvy here in Melbourne. The Rotax manual does indeed say you should get the oil temp up to 100 at least once a day to evaporate any condensation. I have blanked off part of the oil radiator in order to get the temps up to 100, and even then I only really get that on a sustained climb. I even found that in summer (although we didn't get any really high temperatures during summer here this year, and I don't fly if it's really hot anyway) It soon returns to 90 in cruise and sits there. Cheers, Neil
  11. Hi Keith, I recently transferred my Savannah (not a horror aircraft, just an over-regulated LSA!) from 24 to E24. Here's what is involved :- +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Thanks for considering for the ELSA CofA re-issue. Here is a list of points that are required 1. Place the letter “E” in front of the 23 or 24 on both sides of the fuselage registration. 2. Add an “Experimental” placard in clear view - image attached for reference size should be about 50mm high and 300mm long or there abouts. 3. Complete the attached application-CASA form 682 4. Install the updated ELSA warning placard- Sample attached. ’WARNING PERSONS FLY IN THIS AIRCRAFT AT THEIR OWN RISK THIS AIRCRAFT IS NOT OPERATED TO THE SAME SAFETY STANDARDS AS A NORMAL COMMERCIAL PASSENGER FLIGHT CASA DOES NOT SET AIRWORTHINESS STANDARDS FOR EXPERIMENTAL AIRCRAFT’ 5. Provide a copy of the last logbook entry with a TTIS and engine and propeller serial numbers 6. Provide images of the placards and registration and an image of the entire aircraft for the CoA. The cost of the ELSA CofA with the approval for flight over built areas is $770 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ You will need to send the details to Darren Barnfield who is the CASA-authorised person. His email is :- av8tor@bigpond.net.au You can Google "CASA form 682" to get the form. You will also need to submit your current C of A, which you can get from the RAAus website. Good luck! Cheers, Neil
  12. Hi GWH, There's been one at Lethbridge for years. I don't have the contact details but if you call the number listed in the ERSA for Lethbridge I am sure they can put you in touch. Cheers, Neil
  13. Hi folks, A couple of points. Firstly if you just need ADSB-IN you don't need to spend over $1K buying a Skyecho and turning ADSB-OUT off - you can buy a PingUSB device from UAvionix for $395 (under $200 with rebate if you're quick, but still cheaper than Skyecho even with rebate). It displays traffic on your EFB same as Skyecho. You just need a power source for its USB connector from a 12V socket or portable USB battery bank. Secondly I fly near Melbourne airport and frequently see the commercial stuff on my EFB several thousand feet above me. On looking up I then usually spot them (unless they're above the cloud of course). These are more than 10nm away - not sure how much further away they actually appear as I usually have my chart showing just over 10nm. Cheers, Neil
  14. Wow! I use a POSCA red fluorescent marker from Officeworks on my Savvy. I haven't noticed any critters nibbling at it so far, so assume it tastes vile to most! Cheers, Neil
  15. ....shouldn't that be SWMBO? (speaking as a Rumpole fan....) Cheers, Neil
  16. Thanks for posting - I enjoyed watching it. Cheers, Neil
  17. And the hemispherical rules promote the risk of being on a non head on collision course if above 3000ft AMSL........
  18. Still happens.....
  19. Hi Summer, Nothing really to add to what has already been said. I learnt in an LSA and was certainly surprised by the difference the lack of weight of my instructor made and went a bit above circuit height. He also warned me about sink on final as our airfield is in the lee of a mountain and the wind was coming from that direction and sometimes caused sink, but when it happened I was still a little surprised by it. However, I did as taught and added a bit of power which cured the problem. The main thing is to enjoy it - you only do a first solo once!! Good luck, Neil
  20. Hi Danny, Not sure if you wanted ipad info too. I have ipad mini 5, AVPlan and Skyecho2. No problems with setup or use. Cheers, Neil
  21. Hi KA, Sounds weird. I have no problem with my Skyecho and Avplan on my iPad Mini. Suggest you call the AVPlan Support people - I have always found them very helpful. Cheers, Neil
  22. Hi Nev, Wow - I never knew that. It must have been a long time ago as I've been there for about 14 years. As you rightly say - good thing they don't any more!! Cheers, Neil
  23. I recently went to a CASA Safety seminar at Point Cook. We were told we would need photo ID at the main gate to get in as it is a military base. However, an ASIC was not acceptable, but a driver's license was. Sums it up, really. Cheers, Neil
  24. Hi Nev, Not sure where you got the idea that Penfield requires an ASIC - it doesn't, as ERSA will confirm. Cheers, Neil
