Balance Master
bobcharl
FYI - If your engine/prop set up is already well balanced (I performed an obsessive static, followed by a professional dynamic balance) it is my experience that you are unlikely to observe any change in vibration levels by fitting a Balance Master.
My, as yet untested, hope is that should my prop go out of balance eg stone chip then the Balance Master will keep everything relatively smooth running until appropriate remedial action can be taken..
Yes it will. As far as engine balance goes The engine itself is not balanced at all which I find quite distressing and obscene especially for the money you pay for the engine. So realistically you need one on the prop and one on the flywheel. The flywheel end of the engine is out a loooong way
