Best Temperature Instrumentation for Jabiru 2200
Bell Driver
Completing Savannah VG restoration. I'd like recommendations for temperature monitoring. Digital or analog? How extensive-- all cylinder CHT and EGT or just CHT on the rear 2 cylinders. Want simple as possible, but not simpler.
Grown up with steam gauges - easy/intuitive - size & price for all applications. I would recommend coolest (usually front) to hottest (usually rear) monitoring capability. This tells you more than just the worst case (hottest) scenario.
Last couple short flights, our prototype panel had just airspeed and oil pressure. So a good bit of sorting left . The MGL instruments look really woth considering, though as an old guy, would take some getting used to. Nev thinks the way we do. Previous owner had her loaded up--we want simple.
You have to decide what you are going to do about a high temp in the air IF it happens. Don't wait till you are at a scary temp . If it's rising too much increase the climb speed and often you get the same Rate of climb at a higher airspeed. All fine if there's nothing in the way. There may be heat responsive paints about still that will indicate you have exceeded a specific temp. You only need to cover a small area to get the indication. Nev
Seems to me its not just about not exceeding a given temperature ,its having the ability to see that there has been a divergence from whatever you call "normal".
Few if any recreational level gauges should be expected to give what you might call an accurate reading (no matter what you pay) - what they will give is a reasonably consistent reading.
Once you have established the acceptable reading on your gauge/system - record it - then monitor for change.
It is the change that might alert you to potential engine trouble(s).
My arduino system gives me EGT and CHT on each cylinder to the nearest degree and cost very little. The EGT setup was important in getting the temperature spread right, but after that was achieved it is not really needed anymore. The Jabiru system does not have mixture control so once the thing is set up, there is nothing to use if for.
The setup uses a cheap thermocouple board which cannot cope with common earthing, so it uses a clever relay setup. The relay setup and the arduino program were done by an expert clubmate ( Jab 7252 ) and the whole system works fine and cost about $100. ( thermocouple boards for common earthing cost squillions.. this is a hard won bit of knowledge, at the outset I had no idea there was such a distinction ).
If you are an electronic diy person, let me know and I will help if you want to build your own instrument.
MGL Avionics make some nice gauges.
Have a look at lightflying.com.au
For what’s it worth having been an engineer for all my life, while digital look nice when you are up to your neck in a swamp with crocs all around you can glance at an anologue gauge and note the needle position and can tell if it’s right, but in a bumpy ride you have a problem reading the digital values.
For reading the CHT I have thermistors under 1 spark plug per head which all go to a four way switch before a cable goes onto the gauge then I can just rotate the switch to read all the heads (but tend to leave it on no.4 the hottest)
  • Like 3
I feel much the same--using old-school split CHT/EGT gauge with 4-way switch to monitor all, especially #4.1379683437_DSC01775(Large).thumb.jpeg.9824a83c9f62ac248d136ca8d5134857.jpeg
Edited by brinykraut
Hi Brinykraut,
Interesting instrument/engine control layout.
What I see:
2 seat ultralight
Warm weather
In cloud/light rain @ 860 ft (AMSL ?) probably only 500 ft, or less above terrain.
Very low oil temperature - good pressure.
What looks like part of a transever control less frequencies ??
Level/slipping turn @ 75 knots indicated - inclinometer overly sensitive (I have one too)
Engine speed (2500 rpm) indicative of a direct drive engine (Jabiru ?) @ about economy cruise power
Interesting split EGT/CHT - I see your 4 way switch - size & complexity suggests an obsession with engine temps.
Navigation tablet - cant read it very well and I dont recognise the App
Hard wired ELT
What are the two black oblongs (OAT & time?)
Centre engine/ electrical control - recognise all but the "gold" thing top left (Starter??) and the white button bottom right (circuit breaker ?)
For the Jab engine you can get CHT sensors of two types.
Jab recommend the type that goes between spark plug and head. The other is connected to a fin by a screw.
The under plug type tend to break when you undo and do up the plugs. I have changed to the screw mounted type with no problems.
Hey Yenn - when you changed from spark plug to the screw mounted type CHT sensor, did you just change the connector where it attaches to the head or did you install a completely new sensor(s)?
Jabirus need all cylinders monitored, hottest moves around and you have to watch egt
Cht probes need shielding from air blast , under plug ones are hard to centre and seal and break eventually
Terminal screwed to hole between plugs is the go covered in insulation or metal shield
Thermocouple sensors are just the 2 wires joined together. I used 10mm of 3mm copper tube , poked the bared ends in, and squeezed with pliers. I also included a length of stainless steel safety wire ( 30 cm sticking out both sides) so the sender bit could be tied to a cylinder.
The original Jabiru part was a tagged electrical washer and the thermocouple wires were just crimped into this washer.
Mine have lasted several years now
That's not a cheap skid ball!
My teenage kid made mine from with a vinyl tube, ball bearing and two wine corks:
[ATTACH alt=image.jpeg]52691[/ATTACH]
I like that a lot. Simplicity. What liquid?
