Bruce Tuncks Posted July 5, 2020 Share Posted July 5, 2020 My latest worry is about if these things should be overhauled. Has anybody done this ? There are various directives about rubber bits having lives of 2 to 5 years. On a sustainer engined glider I once serviced, all the hoses had to be replaced at 2 years, even though they all looked new to me. I guess that the writers of the directive assume that the worst-kept glider ( tied down outside in the sun ) determines what the rest have to do. In the meantime, although there has been the odd AD or two, overhauling the carb and fuel pump are not in the maintenance schedules that I have noticed. Link to comment Share on other sites More sharing options...
Red Posted August 1, 2020 Share Posted August 1, 2020 Hello Bruce, I'm a newcomer to Jabs, but have a lot of time on Rotax 912 which uses same carbs I tend to view Hoses as an 'on condition' component carb overhaul for the bings If I havn't touched them in 5 years then I will take apart and replace anything needed )Diaphragms I change regardless of how they look). Carb Socket I will also change if it has lasted 5 years (in my experience some can go bad much sooner) I use only Ethanol free fuel, if using fuel with Ethanol id be looking very regularly at my hoses and carb floats Jabiru Fuel pump is a bit of an unknown to me right now 1 Link to comment Share on other sites More sharing options...
Bruce Tuncks Posted August 21, 2020 Author Share Posted August 21, 2020 I have just asked the spare parts guys at Jabiru about a fuel pump kit. The manual says " the fuel pump is replaced as a complete unit" so it may be that this is going to be expensive. Has anybody done this job? What should be a fuel pump life anyway? Link to comment Share on other sites More sharing options...
