Calculating the radius of a skidding turn
Hi all
In a previous post, I said that I did not think that the inside wing of a skidding turn would stall first because the difference in speed was not great enough.
The maths were r(feet)= speed(kts)*speed/11.26*tan of bank angle (degrees)
foxbat turning onto final...
r = 32*32/11.26*tan20
= about 250 ft
speed is proportional to radius, and, at the most, the difference in radii of the wings would be 20 ft. So the difference in wing speed would be 20/250=8%
So, I take it back: because you go so slowly when you stall, if you are in a co-ordinated turn, the inside wing will be significantly slower. One wing at 32 kts, and the other at about 29.5 kts.
But a skidding turn will have a sharper radius than a co-ordinated turn of the same bank, making the difference in speeds of the wing bigger.
And, for those of you who say not to over think it: a) this is for fun, and b) I am not doing these calculations while flying!
I suspect this to be an erroneous assumption also. Skidding will only point you in the direction, you won't actually be going that direction. It's all about the relative airflow.
Regardless of which is the principal factor, it is not a very smart idea to lead into a turn with rudder - a habit which I often see during BFRs.  It is a very, very dangerous habit if you are at low level, or turning final, because it's likely to kill you.
Right from lesson #1, instructors need to be guiding the student towards properly balanced turns at all a-o-b. This is seriously important, because when it comes to slipping the aircraft, the student should immediately, (via L & R 'cheek' feedback), be able to recognise the 'out-of-balance' situation.
Slipping down to an upwind mainwheel touchdown in crosswinds is the worst demonstrated item of both the GA and RAAus syllabus. That probably explains why there are so many R-LOC accidents - most of which are reported as being due to a huge, unanticipated gust of wind!
I can’t check your maths but others have shown in published articles that the difference in wing speed is insignificant
I read the articles, too. It is more likely that they are right than I am right. The faster the aircraft, the smaller the difference in wing speed, too.
 You need to be more  "careful" about those statements. Faster planes will have bigger radius turns for the same angle of bank. Like a motorcycle will have to lean over more on the same corner when going faster. At steep bank angles the radius of turn gets less different as at the (impossible) theoretical 90 degree banked turn the radii are equal. That's one extreme.
 Back to a more normal situation.. Say a reasonable turn radius is 2,000 feet (approx. 1/3rd of a mile the difference in distance travelled is Proportional to the effective wingspan say 20 feet, 20/2,000 is 1%. Not a lot and other factors would come into play like accuracy of rigging and more likely rudder balance. Ball in centre. OR whether you are climbing or descending where the effective variation of Angle of attack of each wing  (due to different diameter helix's being described by each wing) is a factor also. You might recollect your climbing and descending turns  briefings /lessons. Usually the theory s ok but the ability to actually demonstrate holding  bank on or off stick wise is less convincing. It 's still a consideration where right at  the point where the wing stalls, it will happen more to one wing than the other. One goes first. As this happens the downgoing wing compounds it's stall, because of the RELATIVE airflow and the upgoing one temporarily relieves itself. More so when the dynamic loads are higher  Ie in a turn or recovering in a dive.  You then have the plane rolling  uncommanded at stall speed and it quickly becomes a spin if you pull the stick further back  and /or try to oppose the roll with normal aileron application. Again relative airflow.  Nev
Just wow. I hadn’t thought that there will be a natural tendency for a plane to drop one wing when it stalls. Whichever wing stalls first increases its angle of attack and stalls more, and drops more. Whichever wing does not stall, rises, decreases its angle of attack, goes further from stalling and increaes its lift. No wonder some planes (esp with low, laminar-flow wings) can tend to drop one wing in a stall.
Not to mention high wing aircraft without laminar-flow aerofoils ..... I’ve experienced much less tendency for an uncommanded wing drop in low wings with laminar-flow aerofoils (but there are many types that I have not flown). Perhaps something to do with the wing taper, washout ...
Washout gives more aileron control when close or at the stall, but you would be best advised to not count on it. A Cessna-172 can behave very benignly but bite when heavily loaded.  Resist relying on  ailerons UNTIL you get  a more normal flying speed on any plane . Stick relax or forward and power is the go, unless you are already pointing at the ground.  The conventional way of training for stalling is only a box ticking exercise and gives the impression the nose will  be at a crazy high angle when you stall.. People are dying with the turn onto final . Nothing to do with a high nose pitch attitude. .Nev
  • 2 weeks later...
Here’s a great video that talks about both skidding & slipping turns in the stall, explains the aerodynamics of why as well as an actual demonstration of which wing will stall first.
Silly high nose in stall training a tick box?  Maybe in 3axis - but never was when I trained or was training - Stall training in a flexwing will be a lot more than box ticking because you must stall in a turn and demonstrate recovery ... we do not spin but hell we can spiral dive like there is no tomorrow ... and if you don’t know and react quickly there may be no tomorrow for you because vne will be so far behind you SO quickly that recovery itself may break your wing up.
  • 2 months later...
When talk turns to turning, I'd like to hear more about unloading (de-accelerating?) the wing to avoid trouble (especially where max performance is called for).
I'm minded of this by an article (which I quoted yesterday, in another context and thread) by Peter Garrison. He was analysing an accident where an experienced pilot lost control in a snap turn attempting to avoid a mid-air collision.
"Whether from a desire to keep things simple or because its writers actually don't understand the phenomena, the NTSB recurrently makes the error of stating that if an airplane's published stall speed at a certain bank angle is such and such, then, if its wings are at that angle and its speed is below that speed, it must stall. This is not the case. Published stalling speeds for various angles of attack assume level flight. If the pilot unloads the wing in a turn, it will not necessarily stall, no matter how steep the bank."   FLYING (US) March 2019 p28
Thanks for the link DJP.  This is the kind of stuff I find interesting and useful.
But since Jim Alsip is given to pithy paradoxes, any unpacking of the bold bit, below, would be welcome.
(Does he just mean follow the roll with back pressure and not the other way around in a level turn? And if so what's the reasoning?)
"Ailerons do not move the nose of an airplane ... the elevator moves the nose on lateral axis ....
A level turn properly executed demands adherence to this fundamental: Always unload the elevator before using the ailerons."
Yep, Jim is hard work to follow but he has much info available.
"In pilot school, you might have been taught to “hold the nose up” during a turn. If so, did you ever consider that advice could kill you? Consider the fundamental fact that certified airplanes do not stall; pilots cause airplanes to stall."
http://www.dylanaviation.com/stick-and-rudder-what-does-that-mean/
http://www.dylanaviation.com/avoid-loss-of-control-use-the-tape/
http://www.dylanaviation.com/bad-habits-and-improper-turns-can-be-deadly/
http://www.dylanaviation.com/dont-stall/
 A well used phrase is also  'think with your nose down'................ which I use lots during emergency training.
happy days,
