fred cenko Posted December 10, 2016 Share Posted December 10, 2016 I wonder if the Raaus would allow a 19 class registration for this one Link to comment Share on other sites More sharing options...
facthunter Posted December 10, 2016 Share Posted December 10, 2016 Have to be the exact opposite of what would be the appropriate power source. Low thrust engine, High drag plane. Doesn't make much sense. The fuel consumption/ Km would be horrendous. Nev Link to comment Share on other sites More sharing options...
kasper Posted December 10, 2016 Share Posted December 10, 2016 19 reg requires a propeller ... 95.10 does not Link to comment Share on other sites More sharing options...
Birdseye Posted December 10, 2016 Share Posted December 10, 2016 Have to be the exact opposite of what would be the appropriate power source. Low thrust engine, High drag plane. Doesn't make much sense. The fuel consumption/ Km would be horrendous. Nev I think its just a case of "because I can" rather than any practicality. 4 Link to comment Share on other sites More sharing options...
IBob Posted December 10, 2016 Share Posted December 10, 2016 Have to be the exact opposite of what would be the appropriate power source. Low thrust engine, High drag plane. Doesn't make much sense. The fuel consumption/ Km would be horrendous. Nev Dunno, Nev...depends on engine size, and whether the thought of an endless succession of high G loops appeals to you?????? 1 Link to comment Share on other sites More sharing options...
turboplanner Posted December 10, 2016 Share Posted December 10, 2016 Have to be the exact opposite of what would be the appropriate power source. Low thrust engine, High drag plane. Doesn't make much sense. The fuel consumption/ Km would be horrendous. Nev And you would have to constantly change your home field. 1 1 Link to comment Share on other sites More sharing options...
fred cenko Posted December 10, 2016 Author Share Posted December 10, 2016 Would need to get that chute up in a hurry ,away from that bursting heat too. Link to comment Share on other sites More sharing options...
facthunter Posted December 10, 2016 Share Posted December 10, 2016 I bob, the thrust figure would be pathetic. Unless a jet does speed (moves) there is no real power. W = FxS The big break through in Jets was the turbofan. High bypass engine. Nev Link to comment Share on other sites More sharing options...
rolo_ford Posted December 12, 2016 Share Posted December 12, 2016 Doesn't matter how much thrust, once you reach takeoff speed you cannot go any faster, climb rate will change. Link to comment Share on other sites More sharing options...
facthunter Posted December 12, 2016 Share Posted December 12, 2016 That type of flying machine needs thrust= pull. Jets don't have it, especially a pure jet (without bypass) Draggy machines have a great capacity for absorbing power, if you try for speed when the design is not that way orientated. The geometry of a powered parachute (low thrust line) means the vehicle will climb if the thrust is large and I guess you could get into a bit of strife that way if you overdid it. Nev Link to comment Share on other sites More sharing options...
BLA82 Posted December 18, 2016 Share Posted December 18, 2016 At least it would scare the wedge tails away lol 1 Link to comment Share on other sites More sharing options...
M61A1 Posted December 21, 2016 Share Posted December 21, 2016 19 reg requires a propeller ... 95.10 does not Put one on the dash...doesn't have to be a big one. Something about 2" diameter should do it. Link to comment Share on other sites More sharing options...
