The fuel didnt leak from a hose that came off, cable ties are one of the best ties just look at a out board motor tank. The fuel filter was NOT forward of the fire wall as stated. The fuel tank split open. The 747 has wires inside the fuel tank, there is no safety issue with tiring a wire to a fuel proof line to stop it vibiriting, this was removed ,but it will brake with vibrating. there was no shafing of the trim bungee this was made up.the stick yes some one in the work shop has not done a good job here . Have a good look at a piper of such and you can find fault with anything. The reason it never passed the second time we did all the paper work by our tech guy the first thing he said my plane hit a ferris wheel. and then condemned ever thing we had done, no through of how much time and money a small business has put in. Also the guys did walk away and not taken away . I get abusive calls and mail that it flew into a hole, but i can tell you that is not the case ,it took out the two main outer supports and two gondoliers. A 22G main fuse stayed together.So if you think it a crap aircraft you had better take a closer look at the imported craft. Your aussie designed aircraft are going to come out better in a crash.
