jackc Posted May 12, 2020 Share Posted May 12, 2020 Is there such a thing as a ‘stealth’ muffler for the 912? If not, has anyone modified one for less noise, bearing in mind any power loss or drastic weight increase? Link to comment Share on other sites More sharing options...
Blueadventures Posted May 12, 2020 Share Posted May 12, 2020 Is there such a thing as a ‘stealth’ muffler for the 912? If not, has anyone modified one for less noise, bearing in mind any power loss or drastic weight increase? CKT make a quite muffler. I have one and always get told how quite it is. Same comment when I over flew and landed at a forum members airstrip last Saturday. 1 Link to comment Share on other sites More sharing options...
skippydiesel Posted May 12, 2020 Share Posted May 12, 2020 Wow ! you want quieter than a standard Rotax muffler ? My muffler is an off the shelf Rotax 912 ULS job. My aircraft is so quiet I have fitted a siren to get the attention of those on the ground, particularly when contemplating a landing - my "problem ?" is the opposite of yours. Link to comment Share on other sites More sharing options...
Kyle Communications Posted May 12, 2020 Share Posted May 12, 2020 The std Rotax muffler is quite good for noise level and its not a bad muffler either...just the usual outrageous price as everything from Rotax Link to comment Share on other sites More sharing options...
Downunder Posted May 12, 2020 Share Posted May 12, 2020 Ring mounted Rotax's always seem much quieter than bed mounted ones..... Link to comment Share on other sites More sharing options...
Marty_d Posted May 13, 2020 Share Posted May 13, 2020 Talking of this (and sorry, don't want to hijack the thread) - when I bought the second hand 912 he threw in the new muffler, donuts and pipes to make up a new system. (The motor was from a training aircraft with existing muffler in good condition - it made sense for him to keep the old one in place with the new engine). I'm planning the pipes at the moment - as the entry points in the muffler are closer together than the exhaust ports on the engine, the pipes have to angle inwards as they meet the muffler (see picture attached). I know there's a ball-end on the pipes that allows some rotation from straight into the muffler, but am I better off putting a bend in the downward leg of the pipe so the ball end seats straight into the muffler? If you know what I mean! Link to comment Share on other sites More sharing options...
skippydiesel Posted May 13, 2020 Share Posted May 13, 2020 Suggest you check out a number of Rotax 912 installations to get the best "feel" for this. You may find that other factors will influence where and how much you "bend" eg oil filter clearance to facilitate installation /removal without having to loosed/remove the corresponding "pipe" In the end having a good "ball & socket" alignment into the muffler is more important than how much you have had to bend the pipe to achieve clearance (probably a bit of a compromise will be required) Link to comment Share on other sites More sharing options...
Kyle Communications Posted May 14, 2020 Share Posted May 14, 2020 Those ball ends from Flood are very expensive. Danny Leach has made a forming tool and makes his own..they work pretty well too Link to comment Share on other sites More sharing options...
M61A1 Posted May 14, 2020 Share Posted May 14, 2020 Talking of this (and sorry, don't want to hijack the thread) - when I bought the second hand 912 he threw in the new muffler, donuts and pipes to make up a new system. (The motor was from a training aircraft with existing muffler in good condition - it made sense for him to keep the old one in place with the new engine). I'm planning the pipes at the moment - as the entry points in the muffler are closer together than the exhaust ports on the engine, the pipes have to angle inwards as they meet the muffler (see picture attached). I know there's a ball-end on the pipes that allows some rotation from straight into the muffler, but am I better off putting a bend in the downward leg of the pipe so the ball end seats straight into the muffler? If you know what I mean! [ATTACH=full]53179[/ATTACH] Don’t forget to make you can still get your oil filter off and on again with regard to the front left pipe. Mine has a bend that seemS to be for no reason until you pull the oil filter. 1 Link to comment Share on other sites More sharing options...
jackc Posted May 14, 2020 Author Share Posted May 14, 2020 Wow ! you want quieter than a standard Rotax muffler ? My muffler is an off the shelf Rotax 912 ULS job. My aircraft is so quiet I have fitted a siren to get the attention of those on the ground, particularly when contemplating a landing - my "problem ?" is the opposite of yours. My idea is not to piss the local residents off when using my private airstrip, I like minimal noise, even with my cars:-) Link to comment Share on other sites More sharing options...
skippydiesel Posted May 15, 2020 Share Posted May 15, 2020 My idea is not to piss the local residents off when using my private airstrip, I like minimal noise, even with my cars:-) With my standard Rotax muffler my neighbours never seem to know when I am taking off (the noisiest time), dont even look up when I fly overhead. If I want native/domestic animals or people off my paddock/strip, I have to do a very low level pass and/or use my siren or phone family to remove offending objects One additional point : Propeller noise can be/is a big contributor to aircraft noise pollution- I use a Fiti two blade ground adjustable - subjectively sooooper quiet. Link to comment Share on other sites More sharing options...
facthunter Posted May 15, 2020 Share Posted May 15, 2020 Your prop noise is mainly due to some part of the blades going supersonic. Prop RPM's, forward speed and blade dia and to a lesser extent prop section and material. Not an issue with most U/L's. On higher horsepower stuff it's a significant part of the noise envelope on take off particularly. Nev 1 Link to comment Share on other sites More sharing options...
skippydiesel Posted May 15, 2020 Share Posted May 15, 2020 Your prop noise is mainly due to some part of the blades going supersonic. Prop RPM's, forward speed and blade dia and to a lesser extent prop section and material. Not an issue with most U/L's. On higher horsepower stuff it's a significant part of the noise envelope on take off particularly. Nev Cant explain why Jackc's aircraft seems noisy (to him) when mine, with same engine & standard muffler, is so quiet - so have started down alternative explanation track (propeller ?). Other factor could be related to prop wash/pulses against fuselage, bit unlikely but there you go,running out of possibilities. 1 Link to comment Share on other sites More sharing options...
Blueadventures Posted May 15, 2020 Share Posted May 15, 2020 Talking of this (and sorry, don't want to hijack the thread) - when I bought the second hand 912 he threw in the new muffler, donuts and pipes to make up a new system. (The motor was from a training aircraft with existing muffler in good condition - it made sense for him to keep the old one in place with the new engine). I'm planning the pipes at the moment - as the entry points in the muffler are closer together than the exhaust ports on the engine, the pipes have to angle inwards as they meet the muffler (see picture attached). I know there's a ball-end on the pipes that allows some rotation from straight into the muffler, but am I better off putting a bend in the downward leg of the pipe so the ball end seats straight into the muffler? If you know what I mean! [ATTACH type=full" alt="Muffler drawing incomplete.jpg]53179[/ATTACH] Hi Marty you will need to lube the ball ends every 100 hours so each second oil change, so not a big issue even if you had to do every oil change. 1 Link to comment Share on other sites More sharing options...
Blueadventures Posted May 15, 2020 Share Posted May 15, 2020 H My idea is not to piss the local residents off when using my private airstrip, I like minimal noise, even with my cars:-) Hi Jack Re exhausts I’m prepared to bet a carton of beer that my standard CKT exhaust noise is quieter than any standard Rotax exhaust setup. So for quietness they are worth the money and top shelf quality made. 1 Link to comment Share on other sites More sharing options...
jackc Posted May 16, 2020 Author Share Posted May 16, 2020 H Hi Jack Re exhausts I’m prepared to bet a carton of beer that my standard CKT exhaust noise is quieter than any standard Rotax exhaust setup. So for quietness they are worth the money and top shelf quality made. I take they have to be imported? Or available locally? Link to comment Share on other sites More sharing options...
Blueadventures Posted May 16, 2020 Share Posted May 16, 2020 I take they have to be imported? Or available locally? Uk made. Link to comment Share on other sites More sharing options...
CT9000 Posted May 17, 2020 Share Posted May 17, 2020 To make your Rotax quieter just add a turbo. My CTLSt 914 with constant speed Neuform prop is very quiet to the extent that my next door neighbor even commented on how little he can hear it. 2 Link to comment Share on other sites More sharing options...
Farmpilot Posted May 17, 2020 Share Posted May 17, 2020 Wow ! you want quieter than a standard Rotax muffler ? My muffler is an off the shelf Rotax 912 ULS job. My aircraft is so quiet I have fitted a siren to get the attention of those on the ground, particularly when contemplating a landing - my "problem ?" is the opposite of yours. Hi skippydiesel, I have trouble getting sheep off my strip sometimes and have thought of a siren also, can I PM you for details. Cheers, Dean Link to comment Share on other sites More sharing options...
CT9000 Posted May 18, 2020 Share Posted May 18, 2020 I also had to fit a siren to get the wildlife off the runway. I used a burglar alarm siren from the local Jacar electronics aviation supply company. it is surface mount 12v piezo and uses very little current. I screwed it to the firewall. Use a mini toggle switch with supply from the landing light circuit. 1 Link to comment Share on other sites More sharing options...
skippydiesel Posted May 18, 2020 Share Posted May 18, 2020 Hi skippydiesel, I have trouble getting sheep off my strip sometimes and have thought of a siren also, can I PM you for details. Cheers, Dean I also had to fit a siren to get the wildlife off the runway. I used a burglar alarm siren from the local Jacar electronics aviation supply company. it is surface mount 12v piezo and uses very little current. I screwed it to the firewall. Use a mini toggle switch with supply from the landing light circuit. Hi Farmpilot/Dean - Just like Dean I am using a car (12v) burglar alarm siren, mounted on the firewall/undercarriage frame, as close to my cowling air exit as feasible. I use a press switch from JayCar (press on/release off), In my case came out of an old Mercedes wreck, I purchased for parts. So origin unknown but definitely an after market, not an MB original. I started with a motor bike horn but it wasn't quite laud enough. There are heaps on the web, unfortunate you have to take their word and give them the dough, befor you find out how laud they are. Link to comment Share on other sites More sharing options...
Farmpilot Posted May 18, 2020 Share Posted May 18, 2020 Hi Farmpilot/Dean - Just like Dean I am using a car (12v) burglar alarm siren, mounted on the firewall/undercarriage frame, as close to my cowling air exit as feasible. I use a press switch from JayCar (press on/release off), In my case came out of an old Mercedes wreck, I purchased for parts. So origin unknown but definitely an after market, not an MB original. I started with a motor bike horn but it wasn't quite laud enough. There are heaps on the web, unfortunate you have to take their word and give them the dough, befor you find out how laud they are. CT9000, skippydiesel. Thanks for your reply’s. I’ll do a bit of horn hunting online. Cheers. Link to comment Share on other sites More sharing options...
skippydiesel Posted May 18, 2020 Share Posted May 18, 2020 CT9000, skippydiesel. Thanks for your reply’s. I’ll do a bit of horn hunting online. Cheers. Be careful what you confess too Link to comment Share on other sites More sharing options...
Sam the Swiss Posted May 18, 2020 Share Posted May 18, 2020 That's pure fun to read for a Swiss: Chase the sheep from the landing site. We are only allowed to land on aerodromes and airports (except if the fan stops). And on a defined set of glaciers, if you have got the endorsement for that. 1 Link to comment Share on other sites More sharing options...
M61A1 Posted May 18, 2020 Share Posted May 18, 2020 That's pure fun to read for a Swiss: Chase the sheep from the landing site. We are only allowed to land on aerodromes and airports (except if the fan stops). And on a defined set of glaciers, if you have got the endorsement for that. It's not uncommon here to have kangaroo hazards and such on aerodromes. https://www.crc.id.au/xplane/charts/ERSA-2020-FEB-27/Moree%20(YMOR)%20FAC.pdf https://www.crc.id.au/xplane/charts/ERSA-2020-FEB-27/Caboolture%20(YCAB)%20FAC.pdf https://www.crc.id.au/xplane/charts/ERSA-2020-FEB-27/Dalby%20(YDAY)%20FAC.pdf https://www.crc.id.au/xplane/charts/ERSA-2020-FEB-27/Millmerran%20(YMMN)%20FAC.pdf https://www.crc.id.au/xplane/charts/ERSA-2020-FEB-27/Pittsworth%20(YPWH)%20FAC.pdf Link to comment Share on other sites More sharing options...
