Guest bateo Posted February 6, 2007 Share Posted February 6, 2007 G'day guys, I recently encountered a flat tyre on landing, having not found a real answer to what PSI goes into the tyres in the manual, I am wondering what PSI Tecnam owners run in their tyres....?? Your help is appreciated.. Link to comment Share on other sites More sharing options...
Guest Tristo Posted February 8, 2007 Share Posted February 8, 2007 sam, our flight manual for the tecnam says 1.4 bar for the mains and 1 bar for the front. i cant really recall the psi we use off the top of my head but think it mite be 22 for the mains and 18 for the front. maybe??? Tristo Link to comment Share on other sites More sharing options...
Case Posted February 8, 2007 Share Posted February 8, 2007 Sam, Tristo is close with the pressures. If you put ' convert 1.4 bar to psi ' into Google search it comes up with the answers. 1.4 bar is 20 psi and 1 bar is 14.5 psi Link to comment Share on other sites More sharing options...
Guest bateo Posted February 8, 2007 Share Posted February 8, 2007 Thanks Tristo, I put 21 in the sides and 19 in the front so I wasnt too far out... I'll fix it up this afternoon Thanks for that conversion Case, I was unsure of the 1.4 in the manual. Link to comment Share on other sites More sharing options...
Bruce Posted February 8, 2007 Share Posted February 8, 2007 For the last 12 months LSA aircraft ex factory coming in have been 23 psi in the mains and 15 Psi in the nose wheel. Oversize 600 x 6.0 are run at 19 psi Rgds, Bruce Link to comment Share on other sites More sharing options...
Guest bateo Posted February 8, 2007 Share Posted February 8, 2007 Thanks Bruce, I'll need to put a bit more air in them then. Link to comment Share on other sites More sharing options...
Lowflyer Posted March 4, 2009 Share Posted March 4, 2009 Just joining in the forum for the first time, would this also apply to the ultralight version with the small wheels? I am the new guy on the block with a P92 echo ultralight in the U.K. very green yet on all aspects of the plane. Thanks. Roly Link to comment Share on other sites More sharing options...
Bruce Posted March 22, 2009 Share Posted March 22, 2009 Yes, same pressures apply to P92 Echo Link to comment Share on other sites More sharing options...
Lowflyer Posted March 23, 2009 Share Posted March 23, 2009 re P92 Echo brake pads. Thanks Bruce for your reply re the pressures for the Ultralight P92. my Brake pads are getting a bit low now and I am wondering if anyone knows what they are off. A friend here with a Tecnam says they have to come from Italy. Any possible equivalent? Also does anyone know what the rotor arms are off. Mine just say made in Japan, but guess they must be of a Japanese car. They are a bit sloppy in the distributor . Thanks. Roly Link to comment Share on other sites More sharing options...
Guest bateo Posted April 22, 2009 Share Posted April 22, 2009 Roly, There is another thread on here somewhere about the brake pads. Your friend is right, as far as I am aware there is no equivalent alternative. I just recently picked up a set from Italy. They do hold their wear quite well, but can become quite costly. I am sure the process would be a bit quicker and cheaper being in the UK though. Link to comment Share on other sites More sharing options...
Lowflyer Posted April 22, 2009 Share Posted April 22, 2009 re P92 brake pads. Thanks Sam. I am looking into it over here. Will update if i get any news. Thanks. Roly Link to comment Share on other sites More sharing options...
