keith.b Posted October 9, 2015 Share Posted October 9, 2015 Speaking with Jan @ Oshkosh I believe he said he had one on a dyno in the U.K. and was waiting fore the results. not sure why the UK didn't ask. keith.b Link to comment Share on other sites More sharing options...
bexrbetter Posted October 9, 2015 Share Posted October 9, 2015 Hope you are going to do a bit bigger engine too Bex? Yuh, 1.5 and 1.8. Link to comment Share on other sites More sharing options...
Geoff13 Posted October 9, 2015 Share Posted October 9, 2015 In January the D-Motor 4 cyl was going to cost $23,000 ex local agent and the 912 $25,000 Had I purchased the D-motor direct from the factory it would have been about $3,000 cheaper delivered to Brisbane using airfreight. 1 Link to comment Share on other sites More sharing options...
bexrbetter Posted October 9, 2015 Share Posted October 9, 2015 Had I purchased the D-motor direct from the factory it would have been about $3,000 cheaper delivered to Brisbane using airfreight. Hard call isn't it, get burnt locally or if you import yourself and then have a problem later, then who do you turn to. 1 Link to comment Share on other sites More sharing options...
Kyle Communications Posted October 9, 2015 Author Share Posted October 9, 2015 Bex how much HP do you roughly expect from the 1.8? Link to comment Share on other sites More sharing options...
bexrbetter Posted October 9, 2015 Share Posted October 9, 2015 Bex how much HP do you roughly expect from the 1.8? 150hp bought back to lower rpms = 130. Link to comment Share on other sites More sharing options...
Kyle Communications Posted October 9, 2015 Author Share Posted October 9, 2015 wow that would be good for the Rans S20...any idea on the rough weight too?....similar to a 912 would be good :)...may not be possible I suppose but a couple of kilos either way wouldnt matter Link to comment Share on other sites More sharing options...
bexrbetter Posted October 9, 2015 Share Posted October 9, 2015 wow that would be good for the Rans S20...any idea on the rough weight too?....similar to a 912 would be good :)...may not be possible I suppose but a couple of kilos either way wouldnt matter Nope sorry, first cab off the rank will be a good 20kgs on the Rotax, I don't have anywhere near their development budget. My long engine weighs the same as a complete Rotax. More realistic to compare to a Viking, 70% the price, more powerful/torque and brand new engine (BTW, I don't have anything against Vikings use of 30 to 40K kms used engines but seems you're paying $12K USD for the conversion kit? Wow.). Link to comment Share on other sites More sharing options...
Tex Posted October 10, 2015 Share Posted October 10, 2015 ... I am looking at building a new aircraft a Rans S20 Raven .... Nice looking plane that one! 1 Link to comment Share on other sites More sharing options...
jetjr Posted October 10, 2015 Share Posted October 10, 2015 I got a quote from the Dmotor guy here in OZ 2 weeks ago for the 125HP 6 cyclinder and it was around $31,500 delivered to my door inc GST. More than 50% dearer than same spec CAE assuming it includes everything like exhaust prop adapter etc etc Importing makes things expensive and a fit for these AU engines can be seen Link to comment Share on other sites More sharing options...
Kyle Communications Posted October 11, 2015 Author Share Posted October 11, 2015 I looked at the email again it was $32,360 inc GST to my door. My memory must be getting old too. The website quotes everything except the prop http://www.d-motor.com.au/lf_39.html Link to comment Share on other sites More sharing options...
geoffreywh Posted October 11, 2015 Share Posted October 11, 2015 That's an awful lot of money! You can have my aeroplane complete with 1600hrs engine for the same amount! It Looks like Jan's Viking is winner in the price/HP stakes. I wonder if you can insure against non-delivery? I think that the Viking is very good in spite of Jan rather than because of..................Good kit..... 2 Link to comment Share on other sites More sharing options...
saccani Posted October 11, 2015 Share Posted October 11, 2015 so the numbers aren't actually tested by Jan they are just copied off Honda's PR blurb? I can't confirm that. It's worth noting that this wasn't the case with the earlier Viking 100, which had less peak power than the standard Honda engine. Link to comment Share on other sites More sharing options...
saccani Posted October 11, 2015 Share Posted October 11, 2015 2 things;1/ The Viking uses used engines from wreckers, the L15B has only been out for a year. 2/ The L15B is Direct Injection ... end of story for a light aircraft (aftermarket scenerio). I have extreme doubt there is a retail 130hp Viking engine available not that I have any problem with the 110 - 115hp version. With regard to serial 1, they are available from wreckers, and of course, it is easier to get low time L15B than the L15A7. With serial 2, I'm not sure what you have in mind with regard to the aftermarket. The 130 is the only engine being sold by Eggenfelner, the 110 was discontinued. Of course, "addito salis grano" with any recipe containing Eggenfelner as an ingredient is well advised. But it seems a legitimate enough power/torque claim, and within the stated design parameters of the reduction drive. However, as in the past, any reliability data gathered from the in service engines is now no longer applicable. Regards, Paul Link to comment Share on other sites More sharing options...
bexrbetter Posted October 11, 2015 Share Posted October 11, 2015 Saccani, I am referring to the logistics of setting up a L15B Direct Injection engine outside of it's origin, it's difficult, expensive and unsafe relative to flying environment. But anyway, either way I think it's a reasonable package, I have some minor complaints and things I would do differently and some of Jan's performance figures are simply wrong as you can not change physics ... ... but at the end of the day it's getting a few people in the sky a bit more economically and reliably, and that's what's important so the numbers are really just talk. Link to comment Share on other sites More sharing options...
eightyknots Posted October 11, 2015 Share Posted October 11, 2015 How much for just one? You could buy a decent car for that.I am acutely aware more than anyone else of the position I have put myself into on a confidence level about my engine program, but it is actually all happening and about to start setting up factory etc. FaNtAsTiC News Bexrbetter, I look forward to seeing the product come to the market in due time. Link to comment Share on other sites More sharing options...
saccani Posted October 12, 2015 Share Posted October 12, 2015 Saccani, I am referring to the logistics of setting up a L15B Direct Injection engine outside of it's origin, it's difficult, expensive and unsafe relative to flying environment. Well, you're working in that field, I'll take your word for it. I would have thought it would be fairly straight forward (but not trivial), other than in the redundancy of the high pressure side. All the variable valve timing and so on, you would fix in place, I can't see how something like SDS would have an issue with control. As an aside, I see that Viking are selling their old redrive, for the L15A7 for US$3,000. I'm *really* looking forward to hearing about your project. ;) Regards, Paul Link to comment Share on other sites More sharing options...
