naremman Posted September 7, 2011 Share Posted September 7, 2011 I happen to have the good fortune of having a copy of Cliff Tait's book: "Water Under My Wings". For those not familiar with Cliff, he successfully flew an Airtourer around the world in 1969, embarking on the jouney with around 200 hours total time. He was then subsequently employed to ferry NZ made Airtourers, CT4s and Fletcher ag aircraft to international destinations. Over half of his total time was over water, and he ended up with about 100 crossings of the Tasman Sea, all in single engine aircraft. Of the seven engine failures he experienced none ended up giving him wet feet. In Chapter 7 of his book, sub titled Survival, he thoroughly covers how he prepared for the possible ditching of a light aircraft, and it certainly is fascinating reading. "If the surface wind is not more than 20 knots the swell would be of prime consideration and one should avoid touching down of the face of the swell. Touchdown should either be on the back of a the swell or parrallel to it......... If the wind is over 20 knots the resulting reduction in ground speed may be more desirable and an into wind landing preferable." He ends the chapter with a quote from Shakespeare: "All things are ready if our minds be so". I can remember having a chat with Stan Tilley, the affable Taswegian, at one of the Airtourer Association gatherings and we were discussing our respective journies to the function. I mentioned to Stan that I would not be all that comfortable having to cross Bass Straight, and he was quick to counter that he would far rather cross Bass Straight than traverse the Nullabor!! At least Stan has crosssed the Nullabor, whilst I am yet to add a Bass Straight crossing to my flying experiences. Link to comment Share on other sites More sharing options...
Mazda Posted September 7, 2011 Share Posted September 7, 2011 Cliff is a wonderful man, an unknown hero. I'm fortunate enough to have had some good chats with Cliff, he has some great stories. (Naremman it is good to have another Airtourer fan on here). I'm fortunate enough to have flown with Stan too! Now settle down HH, i'm not on here 24 hours a day. Of course it is easily proved with physics and graphs. My suggestion is to ask an instrutor to show you, and failing that get hold of Kermode's Mechanics of Flight, it's an easier read than Aerodynamics for Naval Aviators. I can't remember if it is covered in the Noel Kruse Fly Better books but you can download them for free. Why not try it for yourself? Fly at best glide, then slow down and watch your rate of descent on the VSI. Link to comment Share on other sites More sharing options...
motzartmerv Posted September 7, 2011 Share Posted September 7, 2011 Yes, but i think there is some confusion here. Tex said in an earlier post that if best glide wont let him reach a landable area, then minnimum descent rate will?? Best glide is best glide. Take out variables and this speed will get you the best distance. Minnimum descent will not improve glide performance, ie, it will not stretch the glide out to a new (better)ratio. Changing what the ratio is measured in (from an earlier post of 6:1 to 12:1) does not count. You cant measure glide ratio in height lost over distance covered, and then say you can get a better glide ratio by holding speed for minnimum descent speed. All this is doing is changing what the ratio is measuring, ie, now your talking about VSI over IAS or something like that. Minimum descent speed will NOT stretch a glide (distance).We need to be very clear about this. It will infact make it worse. In most high performance ultralights id only recommend holding minimum descent speed at altitude. For instance the J160 clean stall speed is 58 kts, and the best glide speed is 65. Minimum descent speed is going to be somewhere around 62 kts. And I would point out, in most lighties minimum descent speed is not quoted in the flight manual. Why do you think that is?? cheers Link to comment Share on other sites More sharing options...
Litespeed Posted September 7, 2011 Share Posted September 7, 2011 Back to surviving if you are able to get out of the aircraft- If possible have a personal high end gps locator which has a light strobe. This must be attached to you, by the inflatable vest you are already wearing Naturally this is only inflated after leaving the aircraft. Might as well add a water dye and flare to the vest- can make a huge difference in been found. It is very easy to miss a small object in the sea, esp with a big swell. Another cheap item is a rope throw bag from boating- it has a small float connected to rope in a bag , you hold by a base rope and throw the bag to your passenger etc. It can be used to tie your fellow passenger to you whilst you wait for rescue. Without holding on to each other, it can be very easy to be separated. It will also save heaps of vital energy, conserve energy as much as possible. Assuming you are not critically injured- physical exertion and body heat loss due to immersion are your biggest enemies. The colder the water the less time you have, any injury you have will decrease time of survivability. If someone is unconscious- ensure their air way is not obstructed by the head been slumped forward. Irrespective of injuries, if you can't breath- your dead. Sadly many car crash victims die this way, people who stop don't want to touch them in case they do harm- their f..kin dying- what harm can you do. Naturally you have to get to the water first..................So fly the bloody airplane. Link to comment Share on other sites More sharing options...
Tex Posted September 7, 2011 Share Posted September 7, 2011 Yes, but i think there is some confusion here. Tex said in an earlier post that if best glide wont let him reach a landable area, then minnimum descent rate will??Best glide is best glide. Take out variables and this speed will get you the best distance. Minnimum descent will not improve glide performance, ie, it will not stretch the glide out to a new (better)ratio. Changing what the ratio is measured in (from an earlier post of 6:1 to 12:1) does not count. You cant measure glide ratio in height lost over distance covered, and then say you can get a better glide ratio by holding speed for minnimum descent speed. All this is doing is changing what the ratio is measuring, ie, now your talking about VSI over IAS or something like that. Minimum descent speed will NOT stretch a glide (distance).We need to be very clear about this. It will infact make it worse. In most high performance ultralights id only recommend holding minimum descent speed at altitude. For instance the J160 clean stall speed is 58 kts, and the best glide speed is 65. Minimum descent speed is going to be somewhere around 62 kts. And I would point out, in most lighties minimum descent speed is not quoted in the flight manual. Why do you think that is?? cheers I never said anything of the sort...:baldy: All you have said above is a demonstration of how one dimensional your thinking is. Emergencies rarely are one dimensional. Lets all just theorise about Jabs and use that as the benchmark. (Ignore flaps while you are at it... they wont help at all...) Yes! Minimum sink WILL NOT get you to glide further, but NO ONE has said it would, certainly not me. Knowledge of it and how use that knowledge will! You have completely miscomprehended what I wrote (and ALL theory and practice supports). I guess that is what I get to take away from this: K.I.S.S. Though I thought it was... my apologies if it was my delivery that complicated the matter. "You can lead a man to knowledge, but you can not make him think." In 'Training for flights over water but close to the coast' (or anywhere else) during an engine failure - select best glide (whatever that is?). Tex Out:book: Link to comment Share on other sites More sharing options...
motzartmerv Posted September 7, 2011 Share Posted September 7, 2011 Thanx for your input Tex. Im sorry if i offended you somehow.The post I quoted sounded like you were saying best sink rate would some how get you somewhere that best glide wouldn't. You are correct however, my thinking is one dimensional when it comes to this thread. It is the students thread, and If I can be confused by a post then im pretty sure some students may also. Your points are valid and well founded, but ambiguity breeds confusion, and confusion is a serious impediment to the learning process. Im pretty well versed both on the theory and practical side of what your talking about and also the dimensions of emergencies, having survived several, and if theres one thing ive learned from these emergencies is clarity of thought and presence of mind is crucial. Thanx again and sorry if I upset you. Link to comment Share on other sites More sharing options...
Tex Posted September 7, 2011 Share Posted September 7, 2011 Thanx again and sorry if I upset you. Your welcome and I was in no way upset, I was however quite bemused at how entirely you misrepresented what I had posted (with some support and understanding I thought) adding to any ambiguity and confusion. but ambiguity breeds confusion, and confusion is a serious impediment to the learning process. Yes indeed it does, I did however take this thread to be offering more than education to students, anticipating a significantly higher base level of knowledge amongst a discussion by more experienced pilots. I have reread my posts in order to remove any ambiguity but they are as clear as I can make them with my admittedly inept literary talents. clarity of thought, knowledge and presence of mind is crucial. I fixed this last bit for you Link to comment Share on other sites More sharing options...
motzartmerv Posted September 7, 2011 Share Posted September 7, 2011 Lol, thanx. Just so we are clear, are you a 3 axis flying instructor? ( not derogatory, a genuine question) Link to comment Share on other sites More sharing options...
Tex Posted September 7, 2011 Share Posted September 7, 2011 No What about you? Link to comment Share on other sites More sharing options...
motzartmerv Posted September 7, 2011 Share Posted September 7, 2011 Affirmative...(at least i try to be).. Although sometimes my Job gets made very difficult...;) Link to comment Share on other sites More sharing options...
Tex Posted September 7, 2011 Share Posted September 7, 2011 I caught that before you amended it MM :pokerface: No pressure cficare. Everything I said was correct:thumb up: too advanced? but YMMV Link to comment Share on other sites More sharing options...
motzartmerv Posted September 7, 2011 Share Posted September 7, 2011 ;) Too advanced??...No, i recall a few questions on it in the CPL aerodynamics exam.. The rest of the exam was dedicated to useful info... Link to comment Share on other sites More sharing options...
motzartmerv Posted September 7, 2011 Share Posted September 7, 2011 That was a joke BTW....FYI Link to comment Share on other sites More sharing options...
Tex Posted September 7, 2011 Share Posted September 7, 2011 Your so vain MM... I was (ambiguously) referring to your assertion that: It is the students thread. Astounding position... Not useful info? (Yet it was on your CPL) One wonders why:popcorn: Link to comment Share on other sites More sharing options...
Tex Posted September 7, 2011 Share Posted September 7, 2011 That was a joke BTW....FYI OH I get it Link to comment Share on other sites More sharing options...
motzartmerv Posted September 7, 2011 Share Posted September 7, 2011 ... Touche... Link to comment Share on other sites More sharing options...
motzartmerv Posted September 7, 2011 Share Posted September 7, 2011 Something about flying slightly slower than best glide in a tailwind to make use of the reduced sink rate.. The usefulness to lighties (with an engine) pretty much ended there..;) Link to comment Share on other sites More sharing options...
motzartmerv Posted September 7, 2011 Share Posted September 7, 2011 You realize that most of this banter is going to get modded out hey...?? Link to comment Share on other sites More sharing options...
Tex Posted September 7, 2011 Share Posted September 7, 2011 No not aware of the mod policies, rightly so... we are so far off topic.... like this guy>>> Link to comment Share on other sites More sharing options...
motzartmerv Posted September 7, 2011 Share Posted September 7, 2011 Link to comment Share on other sites More sharing options...
