gareth lacey
Morgan sierra 100
gareth lacey
Hi Kevin
Thanks ,yes the conduit over the tank is for electrical wiring, dual throttles engine probes heat probes,remote brake master cylinder etc and any other things we may put in .
how is the wing build coming?any problem in the building of these? we should start our wings after we fit the canopy (next week pick up) our canopy is tinted and wider than normal i just hope that we get it right first time!!
any way cheers for now Gareth
Kyle Communications
Looking fantastic gareth...the skinning job looks very professional
gareth lacey
Thanks Mark
will try and get over next week to pick those clecos up
cheers Gareth
kgwilson
Hi Kevin
I had to get a new main spar angle as one of them got damaged when I brought the kit home last year. I don't have a bandsaw or ally blade for my circular saw so decided to cut the taper with ultra thins on the 100mm grinder. Worked OK & cleaned it all after clamping both angles together with a flap disc, hand sanding & then fine polishing with 600g wet & dry. Everything is done for the spars but I am waiting on the 5/32 straight rivet bit for my air hammer to arrive from Spruce Goose. The spars are easy but I want to get the solid rivets all the same so opted for a proper polished rivet bit rather than whacking each one with a hammer till they look right.
Everyone tells me that canopies can be a s*!% of a job because as soon as you cut the bubble in half it all goes weird shaped so make sure you cut it a lot bigger than you want to start with.
You seem to have put in quite a few extras, beefed up bits & covers etc. Have you kept a tally of the additional weight & likely effect on CofG?
gareth lacey
Hi Guys
here as some progress pics and vid (i hope i can attach)
pic 1 is actuator mechanism for canopy
pic 2 is actuator canopy side arms
vids
gareth lacey
for all you weight concious people we added 1.7 kilos for the actuator and mechanism all aluminium
wew have a video of the canopy opening but i cant seem to load it ,anyhelp ?
cheers gareth
kgwilson
Gareth,
Just stick it on Youtube & then you can embed that by clicking on the video icon (little film strip) when creating a post. Beautiful job by the way.
gareth lacey
video if opening canopy is on youtube go to sierra pics july ( still cannot get it to load on here!!
cheers gareth
gareth lacey
actuator swing bar and cam523672906_sierrapicsjuly005.thumb.jpg.9b26894c90bb5898772532d2def583a0.jpg523672906_sierrapicsjuly005.thumb.jpg.9b26894c90bb5898772532d2def583a0.jpg
gareth lacey
Cheers Mark
gareth lacey
Thanks Kevin. im not that computor savvy!! cheers gareth
gareth lacey
Hi all
finally finished the canopy fitting, canopy fits the bulkhead perfect,safety locking mechanism is concealed in the side canopy arms, and it is now down off the mezzanine ,starting the wing spars today below are some fuse pics
Kyle Communications
Looking good Gareth
Compulsion
She looks great Gareth. i am really jealous.
gareth lacey
thanks John & Mark
gareth lacey
Hi all
here are a few picks of the wing /strut build for the sierra
645351512_sierrabuildwingspics006.thumb.jpg.90cd2db078e8de66777ddf53d3bcd1c1.jpg the beam jig to hold the strut and the simple adjuster to set the washout
317857241_sierrabuildwingspics002.thumb.jpg.eab8ee4050690fe20bfb8695cc865956.jpg aileron horn
1760831756_sierrabuildwingspics011.thumb.jpg.7c05d5795774413edf76647a9a600e71.jpg alum wing walk/step
2007883285_sierrabuildwingspics012.thumb.jpg.e0eb5fee34ddead7bb3caf5917968f6a.jpg flap,aileron cables through no 7 rib and fuel line
551956319_sierrabuildwingspics013.thumb.jpg.f29e653ad6c508f088d0b971c08f7db1.jpg flap and aileron fitted
1717734874_sierrabuildwingspics003.thumb.jpg.fb2cbeaefcb470ad0630a62f68dd3183.jpg alum 30 litre tank
1577229366_sierrabuildwingspics007.thumb.jpg.deb039e5df2ae83a6fc3edc86aa082ab.jpg tank vent pipe through to wing tip
1914426083_sierrabuildwingspics014.thumb.jpg.3b0bf6134f557dad109991829630acaa.jpg control horn through flap skin(bkt is internal fixed to rib)
the alum tank and wing walk plate with stiffeners weight came to 7 kilos,offset that is less fuel ie less weight next is to skin
cheers all Gareth & CRaig
Compulsion
Looking good Gareth. Can't wait to see her finished and flying. Hope to get up and put some miles under my wings in the next couple of days. Enjoy. Another 2 weeks and I will be up your way Ina cruise ship. Along the coast that is. lOL
gareth lacey
Hi John
thanks, are you enjoying your plane and flying ,and where are you at with x country? enjoy your holiday and dont forget to post some pics of the jab and you flying
cheers gareth
Compulsion
Having a good time thanks Gareth. Might have to get the engine rebuilt as Jabiru believe mine is one of the ones with the circlip issue. L2 can do it while we are away. Aircraft is a joy to fly. I have put off the x country until we get back in November. Trying to get my passenger endorsement so my wife can fly with me. Just trying to really get to know and get comfortable with the Jab.
Runway
Hi Gareth
The plane is looking good. Was there a reason for going for metal wing tanks over Garry's fiberglass tanks, and did you make them? Also, did you have trouble routing the aileron cables around the tanks? We did, but perhaps your cable was longer.
Jeff
keith.b
Any further updates?
Regards keith
gareth lacey
hi kieth i am in adelaide will pm you some more details when i get back to brisbane not posting on general forums fir reasons i will explain cheers gsrrth
