Mr Mal Posted August 14, 2012 Share Posted August 14, 2012 I have a Jab 2200 desperately in need of a good prop. Heard that a Rob Petroni in Bundaberg makes a very good prop for these motors and all accounts mentioning them have nothing but praise. Here is the sticker though - Where is Petroni Propellers and how do I contact them? Appreciate any assistance in tracking down the elusive Petroni Propeller! Link to comment Share on other sites More sharing options...
winsor68 Posted August 14, 2012 Share Posted August 14, 2012 The name has a real ring to it!!! (Sorry doesn't help you locate a contact) Link to comment Share on other sites More sharing options...
Hongie Posted August 14, 2012 Share Posted August 14, 2012 i cant help either... did you buy a morgan? Link to comment Share on other sites More sharing options...
jetjr Posted August 14, 2012 Share Posted August 14, 2012 Rob is a one man show, only makes them as requesed I tried for months to contact him and did no good Be VERY careful with carbon fibre props on 2200. There has been a string of failures. Rob might have been ok though 6 cyl has no such problems. 1 Link to comment Share on other sites More sharing options...
JabSP6 Posted August 14, 2012 Share Posted August 14, 2012 Mr Mal I have a Rob Patroney 3 Blade ground adjustable prop on my 3300 SP6. It has now done over 650 hours and is performing well. Rob also makes a 2 Blade ground adjustable prop for the 3300 so you do have a choice. I also live in Bundy and have been to see Rob several times to montior the prop's condition. I have nothing but high praise for Rob and his props. Safe Flying Andrew (JabSP6) Link to comment Share on other sites More sharing options...
hfrensch Posted August 14, 2012 Share Posted August 14, 2012 I agree ,I have a 3 blade Patroney pro on my 6cyl Jab done 250 hrs with the prop and would not swap back to a wooden prop. Also fitted one to my brothers Lightning 150 hours the only maintenance required so far on both props was a clean and polish. I helped a friend fit a 2 blade one to his 4 cyl,it performs better than the Jab prop and smoother. The downside of these props is that they are weigh more. Cheers Helmut Link to comment Share on other sites More sharing options...
Guest harwis Posted August 15, 2012 Share Posted August 15, 2012 I have wood propellers available for Jabiru motor, maybe I can help. My email:[email protected] Link to comment Share on other sites More sharing options...
waraton Posted May 19, 2016 Share Posted May 19, 2016 I have a Petroni Propeller on my Jabiru. Operating from mostly dirt strips and would like to reduce the constant little touch ups. Heard about 3m propeller tape and have sound advice to only run it half an inch over the leading edge so performance isn't impacted. Interested to hear about other experiences using this tape when using strips which are unkind to props. Any photos of application and Australian suppliers would be helpful. Link to comment Share on other sites More sharing options...
Bruce Tuncks Posted May 25, 2016 Share Posted May 25, 2016 I reckon a carbon prop would give you better performance but it is a reliability risk on a direct-drive engine like the 2200. So my plan is to stick to wood since it must be gentler on the engine. 1 Link to comment Share on other sites More sharing options...
facthunter Posted May 26, 2016 Share Posted May 26, 2016 Safer. If anything should have worked the Sensenich composite should have .Nev Link to comment Share on other sites More sharing options...
jetjr Posted May 29, 2016 Share Posted May 29, 2016 There has been good sucess with carbon props on 3300 but a series of problems on 2200 Something to do with resonance.......... Jabirus fibreglass option seems to be going ok Link to comment Share on other sites More sharing options...
waraton Posted May 29, 2016 Share Posted May 29, 2016 I have a Petroni Propeller on my Jabiru. Operating from mostly dirt strips and would like to reduce the constant little touch ups. Heard about 3m propeller tape and have sound advice to only run it half an inch over the leading edge so performance isn't impacted. Interested to hear about other experiences using this tape when using strips which are unkind to props. Any photos of application and Australian suppliers would be helpful. My Petroni is a 2 blade on a 3300, I am most curious about others experiences using the 3m propeller tape. Link to comment Share on other sites More sharing options...
deadstick Posted May 29, 2016 Share Posted May 29, 2016 Hi, the sensenich wooden prop performs great on my J230. Picked up 150rpm static and cruises better as well. Link to comment Share on other sites More sharing options...
frank marriott Posted May 29, 2016 Share Posted May 29, 2016 Hi, the sensenich wooden prop performs great on my J230. Picked up 150rpm static and cruises better as well. With the 3 or 4 standard ones I have seen fitted to J230s, I agree perform quite well but at the cost of 10kts to cruise speed - consistent with a finer pitch. Link to comment Share on other sites More sharing options...
deadstick Posted May 29, 2016 Share Posted May 29, 2016 With the 3 or 4 standard ones I have seen fitted to J230s, I agree perform quite well but at the cost of 10kts to cruise speed - consistent with a finer pitch. Hi frank, that wasn't my experience I picked up a few knots in cruise. They are a few degrees finer IIRC but I believe the improvements come from the blade profile and the more rigid build. Link to comment Share on other sites More sharing options...
frank marriott Posted May 29, 2016 Share Posted May 29, 2016 That's interesting - I'm confused - but if it works, it works. Link to comment Share on other sites More sharing options...
Bruce Tuncks Posted May 30, 2016 Share Posted May 30, 2016 I used to use the tapes that Bolly sold. One day they said that they were ceasing production, and anyway it was just cut from the stuff you get for your 4WD to stop stone chips. So I cut my own for a few years, until I was told that the thickness of it must be detracting from performance. Now I use 25mm plastic tape similar to Nitto electrical tape and it is easier to change over, which I do quite frequently. Link to comment Share on other sites More sharing options...
