But FAR 23 is clear that at VA, an airplane must be designed strong enough such that the elevator control may be moved suddenly to the forward limit - exactly the same requirement as for back stick or yoke.
  Quote
Agree. The Va for negative is actually your Vs x sq rt of -ve LF. The positive Va is, by example, ( if Vs = 50, so Va = 50 x 1.95 = 98). So in most +3.8 x -1.9 LF aircraft the Va would be considerably lower for negative LF, eg 50 x 1.40 = 70. How does this translate to an aerobatic aircraft - probably is understandable because of their higher LF's? Then add in the rolling forces..... doesn't bear thinking about! happy days,
All correct except that often the inverted stall speed is a bit higher giving a a higher Va
It doesn't because generally the negative limit load factor is much less than the positive one.
Please sign in to comment
You will be able to leave a comment after signing in
