flying dog Posted July 25, 2014 Share Posted July 25, 2014 I was in hobbyco today. I was looking at the models and finally realised which plane I had seen. I knew one of the airbus planes had a "weird" set of wheels. A MIDDLE set. Now I know it is the 340. But looking at the models, there are two kinds of that too! One has a single set of wheels and the other has two sets of wheels. Comments? Link to comment Share on other sites More sharing options...
Guest Maj Millard Posted July 25, 2014 Share Posted July 25, 2014 Heavy jets will often have a centre set of load carrying bogie undercarriage. The DC10-30 had one but didn't always use it so they must have been able to retract it independently ........Maj... Link to comment Share on other sites More sharing options...
facthunter Posted July 25, 2014 Share Posted July 25, 2014 The flight engineer gets a "Bogey Man" endorsement to do that. Nev 1 Link to comment Share on other sites More sharing options...
dutchroll Posted July 26, 2014 Share Posted July 26, 2014 I was in hobbyco today.One has a single set of wheels and the other has two sets of wheels. Comments? There's a very straightforward reason for that. The original design of the A340 - a sizeable long range airliner - required a 2 wheel centre bogie for structural reasons. As is usually the case, aircraft designs change size as airlines demand various extra levels of performance or load capability. This is why for any given airline jet you often see there is perhaps a -200 version, a -300, -400 and so on. Usually they "grow", but occasionally, such as in the case of the B747SP they can "shrink" too. In the case of the A340, it grew, and grew quite a lot. The A340-600 was a much longer and somewhat heavier version, for which the 2 wheel centre bogie did not provide enough structural support. So Airbus engineers had to change it to a 4 wheel centre bogie to cope with this increased load. This was only one of many design changes it needed (including larger engines and so on). 1 Link to comment Share on other sites More sharing options...
facthunter Posted July 26, 2014 Share Posted July 26, 2014 The engineers design a plane and the accountants ruin it. Nev 1 Link to comment Share on other sites More sharing options...
nomis Posted July 26, 2014 Share Posted July 26, 2014 The 340-300 has a MTOW 45 tonnes heavier than an A330. At very light weights the 340 centre gear sometimes doesn't even touch the ground. You can operate the 340 without the centre gear, it stays retracted, but it reduces the MTOW to about 225 tonnes. The 340-600 was up in the 350T range for take off and 247ish for landing needing the extra bogie with brakes. The standard 340 centre gear has no brakes. Yes the 600 was a step too far in size and was a pain to taxi everywhere. Link to comment Share on other sites More sharing options...
alv070302 Posted March 23, 2016 Share Posted March 23, 2016 I think it used to hold the middle part of the plane. Like this: if a wide plane don't have a middle carriage, the body will struck down. I hope you know what i mean Link to comment Share on other sites More sharing options...
