eightyknots Posted August 20, 2014 Share Posted August 20, 2014 Same undercarriage and nose wheel as Savannah and no doubt Spirit and Vision. ...and the Zenith CH701 before that. It is a tried and tested system that has worked well for decades. Link to comment Share on other sites More sharing options...
Guest Andys@coffs Posted August 20, 2014 Share Posted August 20, 2014 so endurance wise....lets see 307kg empty , plus 160kg for 2 Self loading baggage's leaves only 133kg's for fuel assuming a 600kg MTOW so convert that to litres circa 170Litres.......Bladder endurance...no issue bit of side slip for the benefit of the passenger and hang it over the side....... Should be good for a circumnavigation of Australia with only 2-3 stops on the way.........but if you do manage to codge the full 750kg's well then you should be good for >360Litres....... might not need to fill it often but for an RAAus aircraft that is gunna hurt the wallet!! Link to comment Share on other sites More sharing options...
fly_tornado Posted August 20, 2014 Author Share Posted August 20, 2014 The landing gear is the same as the Savannah, one piece aluminum Link to comment Share on other sites More sharing options...
Cosmick Posted November 25, 2014 Share Posted November 25, 2014 Trying to find max weight for front seat Link to comment Share on other sites More sharing options...
