dva51 Posted September 16, 2014 Share Posted September 16, 2014 Hi to RECREATIONAL FLYING FORUM friends I would like to open this new post also here, hoping to support the scenery developer amateurs, introducing my free library for FS9. This "particular" library of object, made with GMax and without adding new textures (it uses the standard generic Building), is currently contains more than three hundred models, and is implemented in time. The library is builded for SBuilder tool, but I think can safely be used by other work packages. Find below the links that refer to the procedure and use the files that allow you to have updates. https://dl.dropboxusercontent.com/u/38829151/FS9/SBuilder/How%20to%20update_Come%20aggiornare.pdf ... here on below you can see the complete preview of the library content https://dl.dropboxusercontent.com/u/38829151/FS9/SBuilder/_SBuilder_dva51.jpg ... here you can see the GUID codes and other info (for SBuilder) https://dl.dropboxusercontent.com/u/38829151/FS9/SBuilder/SBuilder_Codes.txt and here you find the gbl files https://dl.dropboxusercontent.com/u/38829151/FS9/SBuilder/obj_LIB_houses.BGL https://dl.dropboxusercontent.com/u/38829151/FS9/SBuilder/LIB_others.BGL I will not fail to report the following information all here; anyway when you go through the links you'll find the last update docs good sceneries Aldo Link to comment Share on other sites More sharing options...
dva51 Posted September 22, 2014 Author Share Posted September 22, 2014 hello to the interested people as well as about a few additions to the library, I confirm that the summary document images has been revised: now is a PDF file clearer (I hope) with active links to all libraries, and video codes. https://dl.dropboxusercontent.com/u/38829151/FS9/SBuilder/_SBuilder_dva51.pdf greeting Aldo Link to comment Share on other sites More sharing options...
dva51 Posted November 27, 2014 Author Share Posted November 27, 2014 I from Italy just to inform you of a few additions the library (360 items total) the link is always the same, for an overall view https://dl.dropboxusercontent.com/u/38829151/FS9/SBuilder/_SBuilder_dva51.pdf regards Aldo Link to comment Share on other sites More sharing options...
dva51 Posted December 20, 2014 Author Share Posted December 20, 2014 wishing everyone Merry Christmas and happy new 2015 I add a "present" for the scenery-makers with an update of the library; for a bit look, the link is always the same (390 objects present) https://dl.dropboxusercontent.com/u/38829151/FS9/_SBuilder_dva51.pdf MERRY CHRISTMAS! Aldo Link to comment Share on other sites More sharing options...
dva51 Posted February 15, 2015 Author Share Posted February 15, 2015 Greeting everyone , inform you of a couple of additions to the library HT cables for connection to the pylons and a shed-building ... to the next bye from Italy Aldo for those who want to take a full look ... https://dl.dropboxusercontent.com/u/38829151/FS9/SBuilder/_SBuilder_dva51.pdf Link to comment Share on other sites More sharing options...
