red750 Posted March 27, 2019 Share Posted March 27, 2019 Another one with 7 days lapsed. The plane is a Mylius My 103 Mistral, a German 2 seat aerobatic trainer. Not unlike the AESL CT-4. Next one: Link to comment Share on other sites More sharing options...
pmccarthy Posted March 27, 2019 Share Posted March 27, 2019 Mong S1 Sport - this is Tom Aberle’s “Phantom” racer # 62. 1 Link to comment Share on other sites More sharing options...
red750 Posted March 27, 2019 Share Posted March 27, 2019 Too easy. Link to comment Share on other sites More sharing options...
red750 Posted April 3, 2019 Share Posted April 3, 2019 OK No takers. I thought it might be a bit difficult. It's a MÉM-RSZ KSML-1M Nyirség 2 from Hungary. Next: Link to comment Share on other sites More sharing options...
djpacro Posted April 3, 2019 Share Posted April 3, 2019 Varga Kachina Link to comment Share on other sites More sharing options...
red750 Posted April 3, 2019 Share Posted April 3, 2019 I'll have to give you that one, Dave. On checking the history of the Varga, I found that it started out as the Morrissey 1000 (wood and fabric), reworked in metal as the Morrissey 2000, then fitted with a 150hp engine to be called the Morrissey 2150. Design and construction rights were then sold to Shinn Engineering Inc.,who marketed it as the Shinn 2150A. The rights were then sold to Varga Aircraft Corp. This particular machine is shown in airport-data.com, where I got the photo, as a Morrissey 2150A. I tried checking the FAA Register, but the number has been re-assigned to a Sikorsky S-76C. Next: Link to comment Share on other sites More sharing options...
kasper Posted April 4, 2019 Share Posted April 4, 2019 Butt ugly mk.1 1 1 Link to comment Share on other sites More sharing options...
red750 Posted April 4, 2019 Share Posted April 4, 2019 Close, but not close enough. Link to comment Share on other sites More sharing options...
Student Pilot Posted April 4, 2019 Share Posted April 4, 2019 Emair MA-1 Think it was an indigenous Hawaiian Ag machine, 1820 Wright powered? Link to comment Share on other sites More sharing options...
red750 Posted April 4, 2019 Share Posted April 4, 2019 Yes, another aircraft with a few different names. From Wikipedia:: The prototype Murrayair MA-1 was built by Air New Zealand on behalf of Murrayair Limited of Hawaii, United States. Based on the Stearman 75 Kaydet, it had an increased wing area and modification to the forward fuselage to accommodate a pilot (in a raised cockpit for better visibility), a jump seat (used to carry an assistant or mechanic between stations), and a chemical hopper. The fixed tailwheel landing gear was strengthened and a more powerful Pratt & Whitney Wasp radial engine fitted. It first flew in New Zealand on 27 July 1969, then it was dismantled and shipped to Hawaii to obtain United States type certification; Certification was awarded on 14 April 1970.The production aircraft were then designated the Emair MA-1 Paymaster. Production ended in 1976 after 25 had been built. Now this one: Link to comment Share on other sites More sharing options...
Student Pilot Posted April 5, 2019 Share Posted April 5, 2019 Variation on Avid, same as Kitfox/Gazelle/Eurofox. Extended fuse and looks like the gear has been changed from nosewheel to conventional using same rear mounts. Link to comment Share on other sites More sharing options...
red750 Posted April 5, 2019 Share Posted April 5, 2019 It's listed as an American aircraft sold as a kit for homebuilding, without an engine. It may be a knock-off, but the limited info available does not indicate it was based on any other design. Link to comment Share on other sites More sharing options...
Thruster88 Posted April 5, 2019 Share Posted April 5, 2019 Agree with Glenn looks like an Avid, I will just put this one up, owner is a friend, should not be to hard. Link to comment Share on other sites More sharing options...
red750 Posted April 5, 2019 Share Posted April 5, 2019 I will rely on you to tell me if it is an Avid clone. It is a Montana Coyote. 1 Link to comment Share on other sites More sharing options...
Student Pilot Posted April 5, 2019 Share Posted April 5, 2019 What a pretty biplane 2 Link to comment Share on other sites More sharing options...
Thruster88 Posted April 5, 2019 Share Posted April 5, 2019 I will rely on you to tell me if it is an Avid clone. It is a Montana Coyote. Montana Coyote Mountain Eagle by Mountain Eagle » Fri Sep 13, 2013 10:41 am Hello to all, My name is David Staffeldt and I've been storing my project longer than building, but it's time to finish it. I have a kit built by Montana Coyote, Inc. called a Mountain Eagle. It is essentially a 33% upscale of the Avid designed aircraft. It can use up to a 200 hp engine and has a gross weight of 2000 lbs. I plan to post some pictures of it from opening the crate up to where it is now with the changes that were done and the why they were done. Hope that it interests some of you. Thank you, David I guess we were only 66% right ? Link to comment Share on other sites More sharing options...
red750 Posted April 5, 2019 Share Posted April 5, 2019 Thanks for that T88. Link to comment Share on other sites More sharing options...
Thruster88 Posted April 8, 2019 Share Posted April 8, 2019 Agree with Glenn looks like an Avid, I will just put this one up, owner is a friend, should not be to hard. [ATTACH]39051[/ATTACH] Link to comment Share on other sites More sharing options...
Student Pilot Posted April 8, 2019 Share Posted April 8, 2019 Gere biplane, looks rooly good. Where is it based? There is a bloke locally who flew a Fisher Biplane with one of those Rotec radials, sounded VERY good, he had a bit of an incedent down Tyabb way n bent it, not sure if it's going again yet. Link to comment Share on other sites More sharing options...
Garfly Posted April 8, 2019 Share Posted April 8, 2019 I think this is the incident you refer to, Stude. A swarm of keyboard kritics were, needless to say, mightily exercised by the spectacle. Only one YouTube commenter came to the guy's defence. Excerpt from YouTube comments: "bayboos 6 months ago It isn't explained here, but I saw this video way before with an information that the pilot suffered some sort of medical problem during the flight and was not fully capable of making controlled landing. I don't remember what medical problem it was, but apparently serious enough to crash the plane yet stay alive. So please don't jump into conclusions when not having all the information." Link to comment Share on other sites More sharing options...
Thruster88 Posted April 8, 2019 Share Posted April 8, 2019 Gere biplane, looks rooly good. Where is it based? There is a bloke locally who flew a Fisher Biplane with one of those Rotec radials, sounded VERY good, he had a bit of an incedent down Tyabb way n bent it, not sure if it's going again yet. Yes, based on a farm near Cowra Link to comment Share on other sites More sharing options...
red750 Posted April 8, 2019 Share Posted April 8, 2019 OK. Let's keep the ball rolling. Link to comment Share on other sites More sharing options...
pmccarthy Posted April 9, 2019 Share Posted April 9, 2019 One of the many Mignet Pou de Ciel variants. Probably HM293. Link to comment Share on other sites More sharing options...
red750 Posted April 9, 2019 Share Posted April 9, 2019 Listed on source as HM.14. Link to comment Share on other sites More sharing options...
djpacro Posted April 9, 2019 Share Posted April 9, 2019 Micco SP-20 Link to comment Share on other sites More sharing options...
