Guest Crezzi Posted October 23, 2007 Share Posted October 23, 2007 BTW Troy - before you take your children flying you should probably consider whether they would have the strength to fire whichever system you install. I understand they need some level of mechanical force a small child might not be able to apply. Link to comment Share on other sites More sharing options...
Guest disperse Posted October 23, 2007 Share Posted October 23, 2007 BTW Troy - before you take your children flying you should probably consider whether they would have the strength to fire whichever system you install. I understand they need some level of mechanical force a small child might not be able to apply. Good point !! from memory about 9kgs of force. Link to comment Share on other sites More sharing options...
Flyer Posted October 24, 2007 Share Posted October 24, 2007 If you are going to die in one of our aircraft I would wager that the most likely cause will be CFIT. A BRS is not going to help that in general. There are lots of other interventions that can be undertaken to reduce CFIT deaths. Secondly is the matter of weight. From recollection a chute will weigh in at between 12 and 20 kg. As an example a Tecnam has a baggage limit behind the seat of 20kg and if you are at MTOW without a chute then you are leaving either some fuel or your baggage behind. Fuel exhaustion BTW is a major cause of engine failure for GA and I don't expect that we are any different. 20kg fuel is about 27 litres - around 1.5 hours in said Tecnam. In some aircraft the 12-20 kg will be the decider between taking a second person or not in a 2 seater or leaving at all in a small single seater - the chute or the fuel! We need to be aware of some accidents where the chute ends up tangled in the tail surfaces. You are then going down fast, chute not deployed and no tail control surfaces. I unfortunately can't find the link to a rather tragic report I read on this. Regards Mike CFIT... ok, I've just been really stupid and flown into cloud (IMC). I dont have the right instruments, I'm not trained, I'm below LSALT, I've panicked and I've now got 178 seconds to live. Turn the lot off and pull the chute. It gives me a fighting chance at least......Having a BRS may well have saved some people who ended up in this situation. As for weight...that is a penalty that you have to pay. No arguement., however, do you (as the pilot, not you personally) have the ability to lose a few kgs of weight? I know I fit that category :yuk:........ Chute tangled up in tail surfaces, flying controls etc etc....pray a lot..it looks like your time is up...fair point Mike Regards Phil Link to comment Share on other sites More sharing options...
Guest pelorus32 Posted October 24, 2007 Share Posted October 24, 2007 CFIT... ok, I've just been really stupid and flown into cloud (IMC). I dont have the right instruments, I'm not trained, I'm below LSALT, I've panicked and I've now got 178 seconds to live. Turn the lot off and pull the chute. It gives me a fighting chance at least......Having a BRS may well have saved some people who ended up in this situation.As for weight...that is a penalty that you have to pay. No arguement., however, do you (as the pilot, not you personally) have the ability to lose a few kgs of weight? I know I fit that category :yuk:........ Chute tangled up in tail surfaces, flying controls etc etc....pray a lot..it looks like your time is up...fair point Mike Regards Phil G'day Phil The only point that I'd make about CFIT is that there are lots of ways to engage in CFIT and inadvertent IMC is only one of them. As for losing weight - 20kg is more than I can lose. Regards Mike Link to comment Share on other sites More sharing options...
Flyer Posted October 24, 2007 Share Posted October 24, 2007 Hi Mike I've got a few extra kilos if you're interested...;) Phil Link to comment Share on other sites More sharing options...
Guest Baphomet Posted October 24, 2007 Share Posted October 24, 2007 I'm only 95% sure of this, but the weight of the chute doesn't impact on the MTOW calculation, it's an allowance. Re the chute getting tangled, sounds like the result of incorrect mounting. Follow the manufacturers guidlines and it shouldn't be an issue. Re Galaxy repack, I have some observations to make about the process that I couldn't air here, send me a private mail. Link to comment Share on other sites More sharing options...
facthunter Posted October 24, 2007 Share Posted October 24, 2007 Weight of chute Might be an allowance as for floatplanes, ( I'm guessing ), but the weight would HAVE to be included in structural and performance considerations. There's no way around that. N... Link to comment Share on other sites More sharing options...
Case Posted October 24, 2007 Share Posted October 24, 2007 I've seen the allowance for floats in the official documentation but I can't say I've read anything about an allowance for a recovery system. Can anyone point me to where it's written ?. Link to comment Share on other sites More sharing options...
