ADS-B ACT NOW
Sean
You only have a few more days to respond.
HUGE COSTS, ALL PAIN, NO GAIN.
If you feel like I do then tell them, ACT NOW.
And if you don't feel like I do, then do nothing at all.
Here is an email another pilot has just sent me, hope it is of some use to you.
Sean.
tried to email my response and the DOTAR sever blocked it as spam !!! I guess thats one way of preventing complaints.
If you want to try email, send something your response in the format below to [email protected] .
I printed out the attached document, filled it in with the responses below and faxed it to them on 02 6274 7804.
You could also print it and post to the address on the form but please respond somehow. If possible, use your own words for the responses - of course, if your views are different to mine than that won't be a problem ;-)
Joint Consultation Paper Response Form
Transition to Satellite Technology for Navigation & Surveillance
How are you responding to this questionnaire / proposal, i.e. whose views are
represented in your response?
Private individual
Please advise your main involvement in aviation:
Other (specify below*)
* Details: Recreational Pilot
Are you satisfied with the consultation on this issue?
Dissatisfied
Difficult to reply in electronic format. A web response form would have been preferable.
Key Change Proposals The four government agencies invite you to advise your comments on the subject
matter proposed in this JCP by indicating your preference by ticking [] the
appropriate box and commenting below:
Proposed timing of transition to satellite technology for navigation and surveillance
Requirements for carriage and use of ADS-B avionics from mid-2012
Requirements for carriage and use of ADS-B avionics from mid-2014
[ ] not acceptable under any circumstance
This would affect large numbers of recreational aircraft which periodically transit through CTAF®.
The operators of many of these aircraft would have limited or no access to the certified avionics LAME necessary to comply with the calibration requirements. The current CTAF® radio procedures ensure adequate operational safety in these areas. ADS-B should not be mandatory for operation in any Class-G airspace.
Also:
http://www.raa.asn.au/
http://www.casa.gov.au/newrules/airspace/jcp/
http://casa.gov.au/newrules/airspace/jcp/jcp.pdf
