silvercity Posted February 7, 2016 Share Posted February 7, 2016 Anyone experienced loose cylinder head bolts on 912 uls? A mate was checking torque values and found one that won't tighten and can be moved up and down a couple of millimetres. Any thoughts? Link to comment Share on other sites More sharing options...
bexrbetter Posted February 7, 2016 Share Posted February 7, 2016 Never worked on one but you would immediately suspect; Stripped the nut or stud's thread or casing thread or stud is broken. Link to comment Share on other sites More sharing options...
SDQDI Posted February 7, 2016 Share Posted February 7, 2016 Not sure if it the same bolt but have a look through this thread of mine, if it is the same bolt I would say it is broken and will need replacing. Anyway look at the pictures and check the opposite side of the motor, it certainly sounds the same anyway http://www.recreationalflying.com/threads/rotax-914-head-bolt-failure.118178/ 1 Link to comment Share on other sites More sharing options...
Toby1 Posted February 13, 2016 Share Posted February 13, 2016 Torque wrenches in inexperienced hands cause problems Were the nuts slacked off before retorqueing Were the nuts lubricated also Loktite Correct sequence of tightening nots/bolts Head hot or cold Correct figures also Nm or lbft Case of "if it aint broke don't f*** with it" 1 1 Link to comment Share on other sites More sharing options...
silvercity Posted February 15, 2016 Author Share Posted February 15, 2016 The problem has been sorted apparently, not sure of the specific details. He certainly wasn't f*****g with it Toby but thanks anyway. Link to comment Share on other sites More sharing options...
facthunter Posted February 15, 2016 Share Posted February 15, 2016 If one out of four bolts holding a cylinder on, breaks, it is a big deal. It's certainly NOT safe or designed to be used with one missing. I would very much want to know the cause, especially if there are similar breakages occurring.. With a Jabiru just replacing it would not be sufficient, as I would suggest damage could very likely have been done requiring internal inspection. Nev 1 Link to comment Share on other sites More sharing options...
