ajbate Posted June 4, 2016 Share Posted June 4, 2016 Hi, Just wondering if anyone knows where I can buy a large WAC chart that i can put up on the wall? I'd like one that covers all of Australia Thanks, Andrew Link to comment Share on other sites More sharing options...
ajbate Posted June 4, 2016 Author Share Posted June 4, 2016 It's not a WAC, but this is the best I can find. Australia Mega Map Link to comment Share on other sites More sharing options...
Ferris Posted June 4, 2016 Share Posted June 4, 2016 Try Westprint Maps in Nhill Victoria. They may not have a WAC but they do stock a good range. Their customer service has always been very good in my experience. Link to comment Share on other sites More sharing options...
ben87r Posted June 4, 2016 Share Posted June 4, 2016 Normally it's not one WAC but a whole of AUS pack with the edges cut off and then put together. Link to comment Share on other sites More sharing options...
old man emu Posted June 5, 2016 Share Posted June 5, 2016 Normally it's not one WAC but a whole of AUS pack with the edges cut off and then put together. And when you start joining them together, you start to see the curvature of the Earth forming. The edges of the maps don't line up neatly. I hope that you have a very, very high wall to put your map on. Check the scale of the map and compare it to the actual size of Australia. Oh, and start at the top of the wall. OME 2 1 Link to comment Share on other sites More sharing options...
facthunter Posted June 5, 2016 Share Posted June 5, 2016 You are on the ball OME . Different latitudes don't meet at top and bottom edges as they use different standard parallels, as you go north/south. Lambert's conformal orthomorphic is the chart basis and is correct (to a point ) that all actual areas are in proportion to real areas. Constant scale. This is impossible to achieve unless you have the globe as a map, but it's good improve on Mercator, which has enormous distortions of scale near the poles. I've seen large wall aggregations of WAC charts where a fair attempt has been made to match them at the margins but it doesn't really work neatly. Nev 1 Link to comment Share on other sites More sharing options...
DWF Posted June 5, 2016 Share Posted June 5, 2016 G'day aj You will need a bxxdy big wall to fit all the 1:1,000,000 WACs covering Australia - approx 5 * 5 meters. Also, as has been said above, they will fit together side by side but because of the projection (Lamberts Conic Conformal) each 'row' is a different curve and do not match up. A better option for a home or classroom wall map is the 1:2,500,000 Topographic map of Australia. This chart comes in 4 sheets which fit together and cover about 2 * 2 meters. They are available from National Mapping at about $10 per sheet. DWF Link to comment Share on other sites More sharing options...
Old Koreelah Posted June 5, 2016 Share Posted June 5, 2016 Depends how much you love maps, Andrew. I do and have covered a wall with 1:25k topo maps. Even at that scale the lat/long lines are hard enough to line up. If you really, truly want accuracy, curve your wall: apply a bit of maths to the wall framework. With care and water, gyprock can be curved. Link to comment Share on other sites More sharing options...
Birdseye Posted June 5, 2016 Share Posted June 5, 2016 G'day aj You will need a bxxdy big wall to fit all the 1:1,000,000 WACs covering Australia - approx 5 * 5 meters. DWF Yes I remember that bloody wall with WA and the Indian Ocean, chinagraph pencils and perspex templates David. Link to comment Share on other sites More sharing options...
coljones Posted June 5, 2016 Share Posted June 5, 2016 Talk to Kreisha, she does that sort of thing Girl With A Stick: Biggus Trippus 1 Link to comment Share on other sites More sharing options...
hihosland Posted June 5, 2016 Share Posted June 5, 2016 Easier task with ONC charts, not as many to cut and align but the projection challenges are still there Link to comment Share on other sites More sharing options...
Bevan Posted June 7, 2016 Share Posted June 7, 2016 Hi Folks I can arrange to get the AvPlan EFB MegaWAC (Australia wide) printed if you want one. For good resolution its going to be around 2m x 2m in size. If you're interested, email [email protected] and I will put you in touch with the printer. Thanks Bevan.. 1 1 1 Link to comment Share on other sites More sharing options...
Old Koreelah Posted June 7, 2016 Share Posted June 7, 2016 Bevan you might have a market for that sort of chart. Any idea of price? Link to comment Share on other sites More sharing options...
Bevan Posted June 7, 2016 Share Posted June 7, 2016 No idea sorry. I'll chat to the printer. Link to comment Share on other sites More sharing options...
Jaba-who Posted June 8, 2016 Share Posted June 8, 2016 Hi FolksI can arrange to get the AvPlan EFB MegaWAC (Australia wide) printed if you want one. For good resolution its going to be around 2m x 2m in size. If you're interested, email [email protected] and I will put you in touch with the printer. Thanks Bevan.. Just to add some weight to the idea. I'm keen as well. I have spoken to a number of people over the years who have expressed similar wishes that they could get a big map from the WACs. I think there would be a market for these. 2 Link to comment Share on other sites More sharing options...
Downunder Posted June 8, 2016 Share Posted June 8, 2016 Count me in too..... 1 Link to comment Share on other sites More sharing options...
Kyle Communications Posted June 8, 2016 Share Posted June 8, 2016 Count me in too Link to comment Share on other sites More sharing options...
Yenn Posted June 8, 2016 Share Posted June 8, 2016 You do realise that you will have to keep the updates up to date! I remember in the good old days that we used to get updates for WAC charts several times a year. That was a bugger of a job putting them on the charts. Link to comment Share on other sites More sharing options...
Downunder Posted June 8, 2016 Share Posted June 8, 2016 No updates needed if you're just banging it up on the hangar wall as a conversation piece..... 3 Link to comment Share on other sites More sharing options...
facthunter Posted June 8, 2016 Share Posted June 8, 2016 While it is possible to cut and paste and shrink edges to make them match, the maps so produced will not have the accuracy that the original projections had. It's impossible to make a map from a sphere (and a flattened one at that) and transfer it to a flat surface. The "original" WAC uses two parallels of longitude so what is between them is smaller than what is outside of them. The earth's features are projected onto the cone so it's a good compromise for true representation of shape and a common scale for distance over the map surface. The "chosen" Parallels vary depending on the latitude covered so that's the reason they don't match at the top and bottom borders, with adjacent maps. Nev Link to comment Share on other sites More sharing options...
Bevan Posted June 8, 2016 Share Posted June 8, 2016 Our chart will print and be great for a wall. One of our customers had a 5x5 metre copy printed and epoxyed it into the floor of their hangar. Looks awesome! I'll have something in a day or so for you all 5 1 1 Link to comment Share on other sites More sharing options...
Tex Posted June 10, 2016 Share Posted June 10, 2016 I am keen as well. Link to comment Share on other sites More sharing options...
ajbate Posted June 12, 2016 Author Share Posted June 12, 2016 Thanks everyone for the comments and help! Bevan, I'm excited about the opportunity to get a print run of your MegaWAC! I'll measure some wall sizes and get in touch. Is it possible to go bigger than 2m X 2m ? Link to comment Share on other sites More sharing options...
ajbate Posted June 12, 2016 Author Share Posted June 12, 2016 Sorry, just saw the post about the 5 X 5M one that was epoxied to the hangar floor. What a great idea! Only my hangar floor has plenty of cracks in it... we are on black soil that swells and moves every time is rains so concrete always cracks here. I'm thinking I could screw plywood to one wall of my hangar and somehow attach it to the ply. Not sure how I would protect it from moisture and dust- I don't imaging anyone can laminate a 3 X 3 meter map?? Link to comment Share on other sites More sharing options...
coljones Posted June 12, 2016 Share Posted June 12, 2016 Sorry, just saw the post about the 5 X 5M one that was epoxied to the hangar floor.What a great idea! Only my hangar floor has plenty of cracks in it... we are on black soil that swells and moves every time is rains so concrete always cracks here. I'm thinking I could screw plywood to one wall of my hangar and somehow attach it to the ply. Not sure how I would protect it from moisture and dust- I don't imaging anyone can laminate a 3 X 3 meter map?? Speak to the lady of the house. She has been covering kids schoolbooks with contact for years and can give you a very quick and authoritative lesson in laminating without raising a sweat. Link to comment Share on other sites More sharing options...
