facthunter Posted September 4, 2017 Share Posted September 4, 2017 It's a small plane first of all. It's all metal, It looks well designed and quite strong. Being small it will be touchy to fly compared with a VP or such, probably more so as a Tailwheel. Weight is always your enemy. A starter, alternator and battery are relatively heavy components. There's also a lot of work in a 1/2 VW, making the project fairly substantial over all. Nev Link to comment Share on other sites More sharing options...
HJpro7 Posted September 4, 2017 Author Share Posted September 4, 2017 I'm building a tricyle version because its easier to take-off and land, plus I don't need any special training. Is a starter, alternator and battery the only parts required to get a electric startup system. Not intending to build anything else electrical. Also what do you mean by There's also a lot of work in a 1/2 VW, making the project fairly substantial over all. Link to comment Share on other sites More sharing options...
facthunter Posted September 4, 2017 Share Posted September 4, 2017 Most people I know who build them, do it themselves as there are many variants. It's much more work than a full 4 cyl thingy, and they are less common than the "normal" motor by a long way.., You might find it underpowered unless you use some serious performance enhancing mods. The Corby Starlet originally powered by a full VW goes very well with the small Jabiru motor. Don't try to do a 2 cyl version of them. They vibrate excessively due cylinder offset. Have a look at the larger KOHLER V twins.. perhaps?..Nev Link to comment Share on other sites More sharing options...
Litespeed Posted September 5, 2017 Share Posted September 5, 2017 The Hummelbird is a excellent little machine- but is not a novice aircraft. But having accumulated your cert. hours and xc endorsement you should be well on track to flying one. It will be faster to respond and float longer you then expect. A sporty little number. I would forget the 1/2 VW and go a new or rebuilt two stoke- lots more power-plenty in reserve and easy to buy/maintain. Or use a converted V twin or even a pegasus twin. If you can- electric start is very helpful and much, much safer. I would recommend getting air time first and then try as many different types as possible to get used to each type and work out what really suits your needs, abilities and finances. Some love low wing, some love high wing- until you fly them you will not know. Then decide on buy or build and which type. Cheers and good luck. Oh and tell mum and dad to keep you home and spend the holiday money on flying and then a aircraft. USA holidays cost a lot. Link to comment Share on other sites More sharing options...
Phil Perry Posted September 5, 2017 Share Posted September 5, 2017 Another consideration of vital importance is Girlyfriends. AVOID at all costs ! I met one of those and she messed up my flying plans for nearly three years ! ! ! ! Just Joshin' mate. . . Good luck with fulfilling your dream. . . 2 Link to comment Share on other sites More sharing options...
HJpro7 Posted September 6, 2017 Author Share Posted September 6, 2017 After more researching, I leaning over towards wood aircraft since there are usually cheaper and easier to work with. the Kr-2 below. PS. I have worked with wood for the past 3-4 years at school. Link to comment Share on other sites More sharing options...
