Time For Another Quiz
red750
The forums have been a bit quiet lately, and with weather not all that flying friendly, I thought it might be time for another quiz.
What twin engine piston aircraft was converted to a single engine turboprop?
  • Replies 75
It rings a bell, Peter; it's just not ringing loud enough without resorting to the almighty google.
Might need a subtle hint or two.
Cheers, Willie.
Dave C writes "I've no idea ... " fore and aft ? " ... is not a boat is it ?;)"
I was trying to be a little bit cryptic Dave. If I had said "Centre line thrust" I might as well have given the answer myself.
Here's one suggested by our winner, who is naturally excluded from this question.
There have been a number of variable geometry wing aircraft, the best known probably being the F-111. Name another that had a different type of movement, where were the wind tunnel tests conducted, and when did flight tests commence?
Name another that had a different type of movement.
Peter, I'm assuming by 'different type of movement', you mean variable geometry, but not variable sweep like the F-111, F-14, MiG-23, Su-17 & 24, B-1/Tu-160 etc..
Cheers, Willie.
Hi Willie,
Not to be difficult, but I worded it that way to allow you to interpret it. To be more specific may have made it too easy. Do you have a suggestion?
I'm thinking NASA, oblique etc., that's a different type of movement.
As for the original post, looking at the photo above, it took a while for the dots to connect, that the original twin was the civilian version of the FAC Cessna O-2 that came between the Bird Dog and the Bronco.
I thought it looked familar, I'm a bit slow sometimes.
Cheers, Willie.
Are you referring to the Phoenix, manufactured by Phoenix Air USA, from Melbourne Florida, which is certified in the US as an S-LSA Glider? This info from their website:
The Phoenix is both a Light Sport Aircraft, and it is a glider. Consequently, it can be flown by a private airplane rated pilot, a sport pilot, or a glider pilot.
Two sets of wingtips allow a flight span of 35 or 49 feet, with a hangar span of only 34 feet When flown with the 35 foot span, the Phoenix is nimble and quick, with pylon racer flight characteristics.
The dual-purpose Phoenix is THE top of the line light sport aircraft with more versatility and functionality than any other light aircraft.
  • 4 weeks later...
A month since the last brain teaser, time to knock the dust off.
Can anyone identify this aircraft?
