dominicm Posted June 19, 2019 Share Posted June 19, 2019 "IT's TORTUGA TIME !" That's what we heard as our Italian friends from SAB Avio bungee and hand launched their Tortugas into the air to give a hot demonstration of the speed of the new Tortuga from SAB Avio. TORTUGA is a Full sandwich Fiber glass / Airex Fuselage (made under vacuum). - Super rigid, ready for High speed. - All parts are already painted. - Horns are already mounted. - Super-fast assembly, in 2 hours the model is ready to fly. Specification: Wingspan: 84 cm Length: 81 cm Weight RTF: 1.55 KG Wing area: 2400 cm2 Recommended setup: Channels: 4 2 x mini wing servos 30 x 10 x 30 mm 1 x micro servo 12 x 23 mm Flight battery: 6S — 2600 / 3200 mAh Motor: 2200 kV, 28-36mm ESC: 100-120A-ESC, Propellor: 5x5 Max motor size: 36mm diameter Max motor weight: 150 grams Battery Compartment: 55x45x200 mm Link to comment Share on other sites More sharing options...
Deskpilot Posted June 20, 2019 Share Posted June 20, 2019 What a horrible sound. Give me an ICE any day. 1 Link to comment Share on other sites More sharing options...
ClintonB Posted June 24, 2019 Share Posted June 24, 2019 How do you remember which is yours. All the same and way too faaassst 1 Link to comment Share on other sites More sharing options...
dominicm Posted June 25, 2019 Author Share Posted June 25, 2019 How do you remember which is yours. All the same and way too faaassst From experience it's all about minimising blinking and not looking away when they are this fast. 1 Link to comment Share on other sites More sharing options...
