Mike Gearon Posted May 6, 2022 Author Share Posted May 6, 2022 On 5/5/2022 at 12:56 PM, Blueadventures said: Nice Mike You should consider a thread on the build and start with a duplicate of this post. Enjoy and look forward to the progress. Cheers. Thanks. I have thought of this. I see on the forum Mark will start his S21 when current project complete. I wish he was ahead. He’s quite comprehensive and we reviewed his S21 unpack method when doing our own. Helpful! There are I believe 20 plus S21 kits in Australia and at least a few flying. I suspect most of the post activity is taking place on Facebook Rans forums Australia and USA. I’ll look into doing both here and the book. 😀 Link to comment Share on other sites More sharing options...
Mike Gearon Posted July 7, 2022 Author Share Posted July 7, 2022 IFR in actual IFR condition today. Wish I was even 3 years younger. It really is bloody hard. 340 flying hours snd 25 IFR and it’s slowly coming together. Course shows the DME arc for a while until clouds stopped our circle. Twist amd turn 10 degrees on VOR and 10 degrees on heading while maintimg distance from VOR FullSizeRender.MOV 2 1 Link to comment Share on other sites More sharing options...
Mike Gearon Posted July 16, 2022 Author Share Posted July 16, 2022 (edited) Here’s the game changer. IFR clearances can be long…Yeah, I know! As in video… Just write them down and don’t think about them as you do so. A question stops information coming in, Well, that’s what the video says (Sportys IFR course) and I’d like to add you are expected to start on the new heading immediately. ATC don’t like it if you don’t immediately start on new heading. Otherwise, yes. Write and reply then take time to understand. Today was actual IFR. Coming into Crete we had simultaneous hood off and out of clouds. Crete had a breakfast flyin with numerous spectators so landing had to be excellent. 350 hours and 35 IFR hours now. I can’t recommend enough doing and sticking with IFR training. It’s sharpening all the things I’ve learned over 3 years and adding big time. IMG_1092.MOV Edited July 16, 2022 by Mike Gearon Link to comment Share on other sites More sharing options...
facthunter Posted July 17, 2022 Share Posted July 17, 2022 Mike have you been using a clock with elapsed and stop time? When you get used to it you will use it even in VFR. Nev 1 Link to comment Share on other sites More sharing options...
Mike Gearon Posted July 17, 2022 Author Share Posted July 17, 2022 44 minutes ago, facthunter said: Mike have you been using a clock with elapsed and stop time? When you get used to it you will use it even in VFR. Nev Yes, Cessna has a clock with reset. I also purchased a stand alone clock. I absolutely get how useful this is. Especially after prop stop from not setting 30 minute alarm to change tanks! Thanks for asking. I’m with my old CFI tomorrow as safety pilot so he can log approaches and holds. Looking forward to an easy flight for once 😀My job apart from lookout will be working on radio calls. Slowly improving. 1 Link to comment Share on other sites More sharing options...
facthunter Posted July 17, 2022 Share Posted July 17, 2022 You will also use it when holding and entry to patterns and procedure turns. Nev 2 Link to comment Share on other sites More sharing options...
Mike Gearon Posted December 3, 2022 Author Share Posted December 3, 2022 Runway test IMG_8999.MOV 2 1 Link to comment Share on other sites More sharing options...
Old Koreelah Posted December 3, 2022 Share Posted December 3, 2022 Spot on test, Mike! My car has superior suspension and larger diameter wheels, so should give a smoother ride than my plane at 70km/m landing speed. I have only been able to test a couple of potential landing grounds with my car, but the ride has been ruff-as-gutz! Smooth-looking paddocks might knock hell out of your plane. 1 Link to comment Share on other sites More sharing options...
onetrack Posted December 3, 2022 Share Posted December 3, 2022 Yikes! I hope the geese aren't permanent visitors to the airstrip! That airstrip needs a lot more grader work, IMO. Link to comment Share on other sites More sharing options...
Mike Gearon Posted December 3, 2022 Author Share Posted December 3, 2022 (edited) 7 hours ago, onetrack said: Yikes! I hope the geese aren't permanent visitors to the airstrip! That airstrip needs a lot more grader work, IMO. I think the record was about 20 cape barren and 10 swans. Last soft field take off about a month ago I had a close encounter with some variety of bird. Loud thump that turned out to be the front wheel spat. Training drums in to keep the nose down when slow. My new muscle memory training is to keep the nose down then lift and lower again if large birds suddenly appear from nowhere. I was probably a few cm from a prop strike and a possible dip in Westernport bay. 17:1 glide in the Pipistrel may have made the beach or paddock. I’ve practised going to idle and turning after take off. It’s bloody tempting to push in the rudder because the nose looks more like it’s going the right direction. Confident I’d not have tried the impossible turn. Coordinated turn with airspeed and then decision to try to make beach/ paddock or normal full flap landing on water/ mangroves. The Cape Barren are pretty good at getting out of your way. STOL and good manoeuvrability. The swans not so much of either. Grader work…. Yeah, I’ve appreciated your shared knowledge on runways. If I could have had the local grader owner come in when it was disc prepped it would be damn good. He really let me down with unfulfilled promises. My family also in earthmoving business (much smaller) . I’d have brought a road grader over and copped the 2k float charge and 1.2k barge bill. I have a plan for an east west runway down down toward the beach. It’s sandy all weather and protected from southerly winds by the beach tea tree. The birds don’t hang out there either because the grass is crappy. They love to crop the runway short grass and also like us seem to enjoy just hanging out on the lawn. 30 ton Excavator and truck coming soon. Those bloody easterly winds last summer caused some drama. Definitely want to land into the summer easterlies. Well. All that inconsequential with the 220hp turbo S21 tail wheel with tundra tyres. Can pretty much exit the hangar and be in the air a few meters later any direction. The 50ft wing motor glider can sit in the hangar on windy days. It’ll come out for nice thermal days. Looking forward to annoying the pelicans thermalling up mid island before they commute off from great heights. Edited December 3, 2022 by Mike Gearon 2 1 Link to comment Share on other sites More sharing options...
facthunter Posted December 3, 2022 Share Posted December 3, 2022 Whether they are permanent or not is anybody's Geese. Nev 1 Link to comment Share on other sites More sharing options...
Mike Gearon Posted January 11, 2023 Author Share Posted January 11, 2023 Unfortunately the Pipistrel broke loose. I’m thinking it’ll polish out. Not too upset. Link to comment Share on other sites More sharing options...
facthunter Posted January 11, 2023 Share Posted January 11, 2023 Bugga. Dog only knows how those containers get moved around. Nev 1 Link to comment Share on other sites More sharing options...
kgwilson Posted January 11, 2023 Share Posted January 11, 2023 If its just the spinner you got away with it vey lightly. 2 Link to comment Share on other sites More sharing options...
Old Koreelah Posted January 11, 2023 Share Posted January 11, 2023 16 hours ago, kgwilson said: If its just the spinner you got away with it vey lightly. Bugga! But on the bright side, it shows the value of having an easily repaired, non-structural bit take the impact. Link to comment Share on other sites More sharing options...
NME Posted January 22, 2023 Share Posted January 22, 2023 (edited) 9 News - Plane flips at French Island RV9A from Koo Wee Rup. Sad to hear. Glad pilot and passenger are OK. Edited January 22, 2023 by NME Link to comment Share on other sites More sharing options...
Mike Gearon Posted July 29, 2023 Author Share Posted July 29, 2023 There was a tragedy on French island yesterday. A head on collision. One person died and 2 in the other car were airlifted to the Alfred hospital. They are thankfully stable. All friends we have known for 14 years. I’ve had a number of people contact me so mention it here to clear up. One of the things I hoped for from this forum was to make good contacts. I have a number of great friends from my decade in Taiwan. Established through a forum. That finally happened at Osh Kosh. Fantastic to meet Rfguy and Thruster88. We will be organising reciprocal visits between Cowra and French island. Third year at Oshkosh and I’d thought it would be enough and I’d skip a year. Turns out I can’t wait to get back there 2024. Didn’t even get time to sit in on any of the dozens of talks/ lectures. 2 Link to comment Share on other sites More sharing options...
Mike Gearon Posted July 29, 2023 Author Share Posted July 29, 2023 IFR….. I’ve found this more challenging than expected. Considered throwing in the towel about a dozen times and I’ve not given up on anything since a kid. Main impetus to take it on was reading stats that IFR rated pilots are safer. I’d recommend taking on the IFR challenge to every pilot. Even without pushing through to checkride. I understand that in Australia we have another class of IFR that isn’t available in USA. That’s also worth considering for the benefits I’ve seen. I went to Oshkosh with the thought that I’d give it away at this point with heaps learned and strong radio and multitasking skills that just weren’t there 3 months ago. Then, last flight prior to the 8 hour drive had an “aha” moment. I’m sure instructors had mentioned it but I’d not taken on board. Mike had to explain to Mike what needed doing. Last approach before Osh Kosh I was yet again left of runway. Hood up and the disappointment of seeing the runway off to the right. The light came on. Treat the CDI and the external picture as if I’m seeing it then move the aircraft over and dial in runway heading (maybe with a wind correction). I was back in the air yesterday and brought in 3 approaches that were needle Center stable 80kn approaches all the way in. Well, first one I missed a radio call to switch to tower that CFI picked up. Second two were also spot on and I really tuned in the radio at same time with great call outs on altitudes. The big surprise was when the CFI said we better get you ready for your checkride! 9th August is seaplanes at Jack Browns in Florida. Maybe checkride before 2nd September departure. Maybe not. I’ll take it as it feels right and checkride 2024 isn’t out of the question. You get 2 years here after written. Not sure how long in Oz your written stays current. I purchased that hood. One for myself and one for the flying school. 14 dollars well spent. Foggles and glasses don’t mix as well as it’s a cheat. The Lightspeed delta Zulu has saved my arse. I don’t turn it up full volume and the audio frequencies are tuned to help in the 6 high frequencies. Yesterday Omaha approach had static for whatever reason. I’d maybe not have managed the calls with the BoseA20. 2 Link to comment Share on other sites More sharing options...
NME Posted July 31, 2023 Share Posted July 31, 2023 (edited) If I can do it (IFR) you certainly can Mike. also was my first OSH this year. Bucket list ticked. Blown away by the magnitude and camaraderie. Hope to be an annual pilgrim. Best wishes NME Edited July 31, 2023 by NME 1 Link to comment Share on other sites More sharing options...
