Bosi72 Posted October 8, 2020 Share Posted October 8, 2020 I had gusty xwind landing yesterday.. As per normal, wing-down, a bit faster ~70 approach with 10deg flaps, but the gust was still strong.. All the way along the final, the aircraft was experiencing sudden drops, then flying, then drop, then on threshold engine goes idle and flaring, then (unexpected) drop and bang on the ground 🙂 Then, the aircraft still wanted to continue flying, but I managed to keep it on the ground whilst balancing by extending flaps (hand lever flaps between 10 and 40deg) and gently applying brakes whilst keeping the wing down and rudder on the centerline.. Full arms/hands/legs/feet and brain work, but that feeling after the workout - priceless 🙂 Cheers Link to comment Share on other sites More sharing options...
RFguy Posted October 8, 2020 Share Posted October 8, 2020 How to Jab pilots manage getting onto the brakes in a hurry just after touchdown in a pressing condition ? (considering brakes are in the middle). I have long arms and can reach them easily enough I have found , it is NOT a nature maneouver !, - I will miss the differential toe breaks of the Brumby for sure.... Link to comment Share on other sites More sharing options...
kgwilson Posted October 8, 2020 Share Posted October 8, 2020 Hand operated brakes is one of the few drawbacks of the Jabiru and also a lot of other recreational aircraft. Toe operated differential brakes are way better especially in gusty crosswind conditions but all the time in fact. Combine that with a castoring nosewheel and you can spin around with ease in your own length. Link to comment Share on other sites More sharing options...
facthunter Posted October 8, 2020 Share Posted October 8, 2020 Castoring nosewheels don't handle crosswind taxying very well, and ALL nosewheels can experience shimmy. Very few U/L aero brakes are good enough to be called brakes. and wheels are too small and the brakes get hot. A mate of mine destroyed a plane from a brake fire. Use them sparingly.. I "lost" a brake on one side on a straight tail 182 at Sydney (Mascot) in a strong wind taxying...Don't count on your planes brakes too much. That's the message. Nev Link to comment Share on other sites More sharing options...
kgwilson Posted October 9, 2020 Share Posted October 9, 2020 My Matco brakes are excellent. I can lock the wheels up on seal though doing this is not efficient & wears tyres out. I have never experienced shimmy with my setup though plenty do and I don't have problems taxiing in strong crosswinds. Maybe I'm just lucky. Link to comment Share on other sites More sharing options...
Jase T Posted October 9, 2020 Share Posted October 9, 2020 Hand operated brakes are a real PTA in my opinion. Manys the time I have asked a passenger to hold the stick all the way back for me while we taxi along so I can have 2 hands free for taxiing! But it is what it is! Link to comment Share on other sites More sharing options...
Bennyboy320 Posted October 9, 2020 Share Posted October 9, 2020 4 minutes ago, Jase T said: Hand operated brakes are a real PTA in my opinion I agree on the Jab, however on the Foxbat with the Y stick they very user friendly. Link to comment Share on other sites More sharing options...
RFguy Posted October 9, 2020 Share Posted October 9, 2020 I've seen pilots rest their forearms in the Y (for control) on the Jabs (later Jabs have the dual ctl Y stick) and hold the brakes with their hand. didnt look too hard. Other Jab pilots I have seen right over with the throttle hand. depends what is going on I guess. needs a slave actuator somewhere. .. switches on rudder pedals driving actuators I dunno. anyway, sorry, off topic ! That discussion is for another forum topic . Link to comment Share on other sites More sharing options...
turboplanner Posted October 9, 2020 Share Posted October 9, 2020 1 hour ago, RFguy said: I've seen pilots rest their forearms in the Y (for control) on the Jabs (later Jabs have the dual ctl Y stick) and hold the brakes with their hand. didnt look too hard. Other Jab pilots I have seen right over with the throttle hand. depends what is going on I guess. needs a slave actuator somewhere. .. switches on rudder pedals driving actuators I dunno. anyway, sorry, off topic ! That discussion is for another forum topic . The J170 has a short lever and small brakes, and ergonomics where it would be better to start again. You get used to it, But flying a Cherokee with toe brakes and a big wheel brakes that will skid the tyres on dry bitumen (and no that's not what you do) and stop on a dime, you have way more options than the Jab if things get tight; for a start differential braking so you can skid into a ground loop rather than have to steer around into one etc. You are, but something useful always comes out. Link to comment Share on other sites More sharing options...
RFguy Posted October 9, 2020 Share Posted October 9, 2020 The Brumby i have been flying has diff toe brakes. it's an ideal task for toes !!!! that are otherwise unused. I like the idea of using all my body parts. 1 Link to comment Share on other sites More sharing options...
RFguy Posted October 9, 2020 Share Posted October 9, 2020 An big improvement to the Jab would be simply dual levers right next to each other and dual cylinders.... looks a bit like thrust levers of a twin. Should be able to 3D print a pair of levers in fibreglass improved Nylon on a Markforge..... Project # 7. Link to comment Share on other sites More sharing options...
kgwilson Posted October 9, 2020 Share Posted October 9, 2020 Toe differential brakes would be a bigger improvement along with decent discs. The discs they have look like they come from a bicycle, but there is a weight saving I suppose.. Link to comment Share on other sites More sharing options...
RFguy Posted October 9, 2020 Share Posted October 9, 2020 (edited) good weight saving would come from replacing the cast or pressed (depending on which ones you have) steel rims with a Titanium alloy , 3D printed using SLS.... you could build in some fan blades to assist cooling slightly. And there are more advanced discs. Much of the Jab appears to be designed so you can get the parts anywhere and the parts being fairly non critical, low performance spec (like those brake discs). Need to study what is done for toe brake implementation in other airplanes. many options. Electro-mechanical assist to generate pseudo-differential not out of the question- done in F1 cars. 3D print some internal spring flipper lever - pedal that would slide over existing pedals, with electronic inclination sensor (to sense the tilt on the pedal) , take to a controller and drive an actuator for a master master cylinder setup. not as hard as it sounds. In case of fault turn power off to actuator and existing system (centre brake) is unimpeded and functions normally. I'll start a thread on this when I get the airplane. Edited October 9, 2020 by RFguy Link to comment Share on other sites More sharing options...
Thruster88 Posted October 9, 2020 Author Share Posted October 9, 2020 18 minutes ago, RFguy said: good weight saving would come from replacing the cast or pressed (depending on which ones you have) steel rims with a Titanium alloy , 3D printed using SLS.... you could build in some fan blades to assist cooling slightly. And there are more advanced discs. Much of the Jab appears to be designed so you can get the parts anywhere and the parts being fairly non critical, low performance spec (like those brake discs). Need to study what is done for toe brake implementation in other airplanes. many options. Electro-mechanical assist to generate pseudo-differential not out of the question- done in F1 cars. 3D print some internal spring flipper lever - pedal that would slide over existing pedals, with electronic inclination sensor (to sense the tilt on the pedal) , take to a controller and drive an actuator for a master master cylinder setup. not as hard as it sounds. In case of fault turn power off to actuator and existing system (centre brake) is unimpeded and functions normally. I'll start a thread on this when I get the airplane. Glen, why not put a rate gyro coupled to brakes and rudder to stop all that pesky yawing stuff (tail wheel) on the runway. I will keep my aircraft pure and simple. 1 Link to comment Share on other sites More sharing options...
RFguy Posted October 9, 2020 Share Posted October 9, 2020 Hi T-88. Of course that is what is done in remote-control model Helicopters. But don't you think a human does a pretty good job of that in a real aircraft ? I think the remote actuator pedals are a pretty easy implementation. Will think about it some more.. Jab doesnt have full castering nose wheel (?) so I guess diff brakes for turning at ends of strips is of limited value for that nosewheel. I may be wrong about the Jab nosewheel limitations. Or does it caster beyond the pedal control ? Link to comment Share on other sites More sharing options...
facthunter Posted October 10, 2020 Share Posted October 10, 2020 You have to stop making micro-Processors run your plane. Make it so the pilot FLYs it. Powerful brakes either lock wheels and can spot tyres or cause them to blow or impose large loads making differential braking most use only at lower speeds. Tailwheels ARE steerable when the tail is on the ground, if it's set up correctly. Generally unless there's some propwash once you've slowed up, the rudder would not have much authority especially ones that are small and have rather short tail moment arms. A dorsal fin helps energise rudders but you still need a decent airflow. Nev Link to comment Share on other sites More sharing options...
RFguy Posted October 10, 2020 Share Posted October 10, 2020 Dont worry Nev, per my comment to Thruster (I said) "But don't you think a human does a pretty good job of that in a real aircraft ?" there are some things the pilot should be doing. He She is not doing it all day. and humans have proven reasonable pilots. However, the toe brakes on the Jab would be nice. I'll be interested to see just how "equal" the left and right brakes are until moderate braking. My guess is under heavy braking, they'll be (expected) to be similar- where max clamping force on the disc that the little caliper can muster, is applied, all things become equal. ideally. I've found pad and disc INcompatibilities more of an issue in motor vehicles than anything else. IE pad doesnt like to be teamed up with that disc. BTW- no microprocessors need be involved, to nit pick :-) Link to comment Share on other sites More sharing options...
kgwilson Posted October 10, 2020 Share Posted October 10, 2020 You don't have or need power assistance with light aircraft toe (or any other sort) brakes but it is important to set the geometry up with the appropriate ratio of pedal pressure to braking force to get a good feel for their operation from very light through to heavy brake action. Link to comment Share on other sites More sharing options...
RFguy Posted October 10, 2020 Share Posted October 10, 2020 Hi KG yeah that's the thing isnt it, any toe brake solution really needs to have pressure feedback like a real pedal. cannot be just a inclinometer on a spring. needs back pressure. I'll take a really good look at the Brumby next time I am in it. -glen 1 Link to comment Share on other sites More sharing options...
turboplanner Posted October 10, 2020 Share Posted October 10, 2020 39 minutes ago, RFguy said: Hi KG yeah that's the thing isnt it, any toe brake solution really needs to have pressure feedback like a real pedal. cannot be just a inclinometer on a spring. needs back pressure. I'll take a really good look at the Brumby next time I am in it. -glen That's called modulation and is a part of the design process. The brake performance and wiindow of operation between these two aircraft is like chalk and cheese, so is the price. Link to comment Share on other sites More sharing options...
facthunter Posted October 10, 2020 Share Posted October 10, 2020 You can easily smoke a tyre with Clevelands ..IF you are serious you must have anti skid. Differential braking is a must. If you have a flat tyre on one side for instance you have to equal the drag at least. Nev 2 Link to comment Share on other sites More sharing options...
turboplanner Posted October 10, 2020 Share Posted October 10, 2020 1 hour ago, facthunter said: You can easily smoke a tyre with Clevelands ..IF you are serious you must have anti skid. Differential braking is a must. If you have a flat tyre on one side for instance you have to equal the drag at least. Nev You can but there's enough modulation on the Cherokee that only a hoon would; fabulous brakes. Re the anti skid, I checked the Textron Skyhawk Specification sheet, but it doesn't give much detail other than overall dimensions. Link to comment Share on other sites More sharing options...
facthunter Posted October 10, 2020 Share Posted October 10, 2020 You don't have to be a hoon .If your seat is not correctly adjusted or your feet positioned optimally, you might accidently apply the brakes enough during rudder application to momentarily lock one. There's varying amounts of lift involved also as well as cross wind and it's effects,. Anti skid reduces tyre blowouts BUT our planes have LOW stall speeds remember, so don't need F1 Brakes. Tiny wheels don't have enough room to build bombproof brakes. Brakes have to absorb generated heat and that ability is always limited even with the best. Nev Link to comment Share on other sites More sharing options...
