skippydiesel Posted June 10, 2021 Share Posted June 10, 2021 On the hunt for that special aircraft - must conform to as many of the following wants (list not prioritised) as possible: Privately owned Private sale (ie not through a broker) Well used airframe/engine Log Books (not interested in the flight log per say) with comprehensive service record If kit - Good Build Log Where applicable - Detailed accident/incident record and repair All AD's, Mandatory Modifications up to date & documented as such Rotax 912 ULS motivated (my apologies to Jab supporters) Would like to have a 120 knot econamy cruise (or better) Econamy in this context, is about 16 L/hr . It would be great to have a low stall, say 35 knots or better My preference would be for a composite airframe ,however all considered 80-120L fuel capacity (range) 300kg empty weight, give or take 450 - 600kg TO weight - higher again would be a small advantage for when RAA gets the increase 1000 Hobb hrs or less - will consider new engine in well maintained airframe Will not pay extra for a fancy panel - I am a day VFR pilot It does not have to be immaculate, just well cared for (loved). Link to comment Share on other sites More sharing options...
onetrack Posted June 11, 2021 Share Posted June 11, 2021 Skippy, you don't state a budget level, which will help. Here's a local (W.A.) aircraft that may fit your requirements, although it may be priced outside your budget level. It's currently VH registered but it appears it would be no problem to revert it to RA registration. https://www.gumtree.com.au/s-ad/yokine/miscellaneous-goods/2011-pipersport-aircraft/1275064299 Here's a flight report on the aircraft. It appears the stall speed is 34 kts in the landing configuration. https://www.australianflying.com.au/news/pipersport-lsa-flight-test-a-new-beginning Link to comment Share on other sites More sharing options...
skippydiesel Posted June 11, 2021 Author Share Posted June 11, 2021 Thanks for that 1T - looks very nice - could just about stretch to the asking price however seems a bit high for a 1/2 life engine (probably the fancy panel) and a tad outside the performance criteria- will make contact and see where it leads. Link to comment Share on other sites More sharing options...
skippydiesel Posted June 11, 2021 Author Share Posted June 11, 2021 Don't know how I have two conversations, on same heading/topic, going at the same time????? Link to comment Share on other sites More sharing options...
pmccarthy Posted June 11, 2021 Share Posted June 11, 2021 Empty weight is a bit high in the Piper Sport. Link to comment Share on other sites More sharing options...
skippydiesel Posted June 11, 2021 Author Share Posted June 11, 2021 39 minutes ago, pmccarthy said: Empty weight is a bit high in the Piper Sport. True! I am inclined towards the impression that it is mostly good looks, with modest performance. Link to comment Share on other sites More sharing options...
