spacesailor Posted January 27, 2022 Share Posted January 27, 2022 Mitsubishi 4M40 turbo diesels have ' throttle bodies ' ,. It stops ' runaway ' diesels, when there,s too much fuel in the sump. Leaking fuel pump O ring, does that, then the sump fuels the motor. Reverse running diesels will suck up the tail pipe and go to uncontrolled revs, then self destruct. spacesailor 2 Link to comment Share on other sites More sharing options...
RFguy Posted January 27, 2022 Share Posted January 27, 2022 wow 1 Link to comment Share on other sites More sharing options...
Markdun Posted January 27, 2022 Share Posted January 27, 2022 The other way Spacey is for engine lubricating oil to leak into the air inlet via a failed turbo bearing and the diesel engine will also do an uncontrolled runaway unless you are quick enough to put in fifth gear, drop the clutch while standing on the brakes. Best advice is to stop, get everyone out, stand back a good distance and watch and listen to the self destruct. Link to comment Share on other sites More sharing options...
spacesailor Posted January 27, 2022 Share Posted January 27, 2022 Or !. Just block the Exhaust pipe !. Works on the principal, that it can,t keep the fire burning with a blocked chimney. Even a big v8 will stall when backed into the drainage ditch at macay airport. . Long time ago, but some could remember, running over to assist the poor embarrassed motorist. Yours truly spacesailor Link to comment Share on other sites More sharing options...
facthunter Posted January 27, 2022 Share Posted January 27, 2022 Good if it's running backwards but that's only the case in a low % of events. When it's going backwards, the motor and turbo get no lube oil. Nev Link to comment Share on other sites More sharing options...
Markdun Posted January 27, 2022 Share Posted January 27, 2022 Do you mean the potato jammed up the exhaust pipe prank? Don’t think it works all that easy at 8000rpm. I’ve only ever had an aero 2 stroke Diesel engine running backwards..... can’t recall whether I stopped it with a rag in the prop or my fingers in the prop....in the days of youth and control line model planes. 2 Link to comment Share on other sites More sharing options...
Flightrite Posted January 28, 2022 Share Posted January 28, 2022 How do you blokes sleep at night worrying about all that crap?😉😉😉😂😂🙁 Link to comment Share on other sites More sharing options...
facthunter Posted January 28, 2022 Share Posted January 28, 2022 Exercise your brain and it will atrophy slower. Nev Link to comment Share on other sites More sharing options...
Markdun Posted January 28, 2022 Share Posted January 28, 2022 My wife tells me that once my head hits the pillow I take 5 breaths and I’m fast asleep until sunup. She takes ages to go to sleep worrying about the state of the world, children starving and abused, people mistreating animals and all the other women (the sisterhood) around the globe awake & concerned, or tending their awake hungry babies. I think all the crap I think about is so unimportant it’s not worth worrying about and lose sleep over. 1 Link to comment Share on other sites More sharing options...
spacesailor Posted January 28, 2022 Share Posted January 28, 2022 In my youth l have had ' Peter ' & Lister ' hand cranked diesels running backwards ,. Luckely l suvived with all my fingers intack. Those Dammed hand cranks Don,t let go, when in reverse ! & will break both your arms, easily. Rusten Bycrus dragline machines have a ' donkey ' engine to start the big engine with not much room for a large handle flaying about spacesailor Link to comment Share on other sites More sharing options...
facthunter Posted January 29, 2022 Share Posted January 29, 2022 Don't they have a decompressor for starting? Nev Link to comment Share on other sites More sharing options...
Yenn Posted January 29, 2022 Share Posted January 29, 2022 Listers did. It was a wheel in a groove on the flywheel. Two revolutions to get up to speed then it disengaged and the valves closed. Starts first time every time. Same for Marshall tractor engines. 2 Link to comment Share on other sites More sharing options...
