skippydiesel Posted January 30, 2022 Share Posted January 30, 2022 My new Sonex comes with the antenna (transponder & transceiver) locations already drilled. I have no concerns over the transceiver location, however the transponder has been located just 500mm away. My very limited understanding/experience strongly suggests that the two antenna should be no less than 1m apart. My questions are; What is the recommend minimum distance between antenna (particularly transponder/transceiver) ? What effect/impact (if any) might I expect from such close location ? Link to comment Share on other sites More sharing options...
RFguy Posted January 30, 2022 Share Posted January 30, 2022 (edited) Skip, 1) the Xponder antenna and the VHF can be next to each other... but try and keep them at least 2 x transponder antenna lengths apart to reduce the potential for unwanted directivity of your transponder due to the proximity of the VHF . 2) the Xponder ant wont bother the VHF. 3) For 2 x VHF, I'd recommend min of 2.5 meters and as far apart as practical. SKip , how can your "limited understanding" " strongly influence "?? surely a limited understanding should weakly influence your thinking? Edited January 30, 2022 by RFguy Link to comment Share on other sites More sharing options...
skippydiesel Posted January 30, 2022 Author Share Posted January 30, 2022 1 hour ago, RFguy said: Skip, 1) the Xponder antenna and the VHF can be next to each other... but try and keep them at least 2 x transponder antenna lengths apart to reduce the potential for unwanted directivity of your transponder due to the proximity of the VHF . 2) the Xponder ant wont bother the VHF. 3) For 2 x VHF, I'd recommend min of 2.5 meters and as far apart as practical. SKip , how can your "limited understanding" " strongly influence "?? surely a limited understanding should weakly influence your thinking? Limited experience (virtually no understanding) - I installed both transponder & transceiver (VHF) on my Zephyr. Followed suppliers instructions (strong influence) to the letter (including minimum distance 1 m). To my absolute delight/surprise both systems worked perfectly. Sonex came with antenna location decisions already implemented - hence concern. Transponder antenna length - its a "blade" type. I assume hight of blade also hight of antenna, so well in excess of your X2 recommendation. 1 Link to comment Share on other sites More sharing options...
