Speed tape
1 hour ago, facthunter said:
GAP sealing is known to provide advantages of less drag and more effective control function. You have more difficulty oiling the hinges. Nev
Maybe just leave the hinge exposed
I made up my own seals using Mylar strips & HD double side tape. As  above sugestion, left hinges exposed. Subjectively worked well.
Take great car that you dont restrict control surface movement.
Check out :
 https://wingsandwheels.com/gap-seal-tape.html
 https://www.cumulus-soaring.com/store/bowlus-tape-white-1in
https://www.homebuiltairplanes.com/forums/threads/aileron-gap-seal.20995/
I use Leukosilk tape 50mm wide which you can buy from a chemist. Its simple and it lasts about 10-15 years, is white and can be spray painted with acrylic or Stits Polytone which not only makes it conform to your livery but also protects it from UV.  I use it to seal the wing root/wing fairing gaps on the Corby and the rudder and elevator gaps in the Cygnet.  On some hinge joints you need quite a complicated tape arrangement and this would be the case for the Frieze ailerons on the Cygnet and all the Corby control hinges.  The glider people are full bottle on those.
