Video of crash - plane into car - USA
EFATO and stall at under 300 feet. Guaranteed crash, usually fatal as it was in this case. Shame they took out someone on the ground as well.
Some time ago, a group of fairly highly skilled and trained aviators did an experiment on “The impossible turn” back to the runway after an EFATO.  The planes they tested could do it from 500’ AGL or so, all but the Bonanza. No matter what height they tried it at with the Bonanza, it never made it even close to the runway.
This is the vid us AOPA made. It shows their head of safety doing the turn back in his super cub with the stall warning going off. Not good form from someone making a supposed safety video.
Conclusion. Don't turn back.
These were all highly skilled and trained pilots. A good comparison would have been to find 3 pilots with normal flying skills who have never tried or practiced turnbacks & checked the results. The risk though would have been a stall/turn & crash. If not I doubt that any except the cub would have made it & they were all from 1000 feet. The cub was from 300 feet twice & 500 feet once & the stall warning was going off most of the time. He made it due to his expertise but the stall warning should have invalidated the test IMO.
Sorry, I'm a bit dim. They said it happened shortly after takeoff. How do you know it's EFATO and stall? Agree this is likely.
Edited by cooperplace
They also don’t mention other added stresses. Violent engine failure with associated noise and oil spraying everywhere!
hysterical passenger especially sitting next to you!
The only other thing that should be mentioned is that the need to get back on the RWY should NOT be the priority, the whole airfield should be clear enough to make an emergency landing!
