Field tank liner
Tasmag
I am looking for 2 bottles of the fuel tank Kreem that Jabiru used for lining the wing tanks.
Unfortunately not able to be sourced in Australia anymore, was hoping someone has some laying around.
Mike
You can acquire Kreem from the U.K. via eBay ....
https://www.ebay.com.au/itm/384669559510
There's also KBS and POR-15, both readily available. I don't know if these two products are as flexible as Kreem when set, but I've used POR-15, and it is an exceptionally good product.
https://www.ebay.com.au/itm/274974376963
POR-15 is readily available from eBay - otherwise, many paint distributors carry it, or can get it in for you.
Don't buy too much, once you mix the batch of epoxy, the entire can must be used, you can't store leftover POR15 for later use.
https://porproducts.com/buy-por-15-in-australia
Edited by onetrack
