Garfly Posted September 4, 2022 Share Posted September 4, 2022 Another fatal wherein high DA, low perf and downdrafts are seen as suspects. (It seems that the aircraft was a Comanche not a Cherokee as stated in this video.) And below is a video made by a local flyer in a bid to better educate visitor aviators about local conditions. http://www.kathrynsreport.com/2019/10/fatal-accident-occurred-october-20-2019.html 1 Link to comment Share on other sites More sharing options...
Flying Binghi Posted September 4, 2022 Share Posted September 4, 2022 Interesting to see the spray of fuel out of the ruptured fuel tank. . Link to comment Share on other sites More sharing options...
poteroo Posted September 9, 2022 Share Posted September 9, 2022 Have flown 180/250, 260, 260B, 260C models. The 180HP Comanche is a poor performer in higher DA, eg, >5000. Hard to accurately lean a carby engine for best power take-off. FI better, but need a multi point EGT as well. No info as to configuration for take-off, nor the technique used to rotate and if it was held in ground effect to gain IAS. All very important. Wonder if pilot had any form of training, or any briefing on high altitude ops? 1 1 Link to comment Share on other sites More sharing options...
facthunter Posted September 10, 2022 Share Posted September 10, 2022 Were the wheels retracted?. These planes have a simple flap that doesn't provide good extra lift for the extra drag involved. I calculate the DA to be under 9,000 feet. The "service" ceiling is where you still make 500 FPM and I would have thought would be around 12000 feet at least. The wings are of the Laminar flow type where they stall more sharply than others and you need to have the right speed and not be slow. Turbulence degrades performance also. Nev Link to comment Share on other sites More sharing options...
poteroo Posted September 12, 2022 Share Posted September 12, 2022 At these high DA the mixture must be leaned to get the peak RPM. Because the MP is very much lower - take off 1" for each 1000 alt, the aircraft can be held on brakes then carefully leaned. In this case it would probably have only made 21-22 " MP, (60% power?). FWIW, I would have leaned it, then used every metre of runway in a 'rolling' take-off,but zero flap. Then, rotated by clicking in flaps 1 via the reliably positive manual flap bar - but holding in ground effect while retracting. There are undoubtedly other factors involved, eg engine condition, but 180HP........... you are always going to struggle. Having a substantial downhill slope,(5-15%), was our saviour in PNG, where OPS at 7-10,000 DA were common. 1 Link to comment Share on other sites More sharing options...
Thruster88 Posted September 13, 2022 Share Posted September 13, 2022 (edited) 9 hours ago, poteroo said: At these high DA the mixture must be leaned to get the peak RPM. Because the MP is very much lower - take off 1" for each 1000 alt, the aircraft can be held on brakes then carefully leaned. In this case it would probably have only made 21-22 " MP, (60% power?). FWIW, I would have leaned it, then used every metre of runway in a 'rolling' take-off,but zero flap. Then, rotated by clicking in flaps 1 via the reliably positive manual flap bar - but holding in ground effect while retracting. There are undoubtedly other factors involved, eg engine condition, but 180HP........... you are always going to struggle. Having a substantial downhill slope,(5-15%), was our saviour in PNG, where OPS at 7-10,000 DA were common. It is easy to lean for maximum rpm and therefore power with a fixed pitch propeller. With a constant speed hydraulic control propeller how would the pilot know when it is producing maximum power? I don't think I was ever taught this. Edited September 13, 2022 by Thruster88 Link to comment Share on other sites More sharing options...
