APenNameAndThatA Posted October 10, 2022 Share Posted October 10, 2022 I copied this idea from Youtube. That is Bourke, NSW, with the hole in their parking area. 3 Link to comment Share on other sites More sharing options...
facthunter Posted October 10, 2022 Share Posted October 10, 2022 Cunning. Replace all divots. Nev 1 1 Link to comment Share on other sites More sharing options...
APenNameAndThatA Posted October 12, 2022 Author Share Posted October 12, 2022 Yup. And the wood went back behind the rural brigade shed. 1 Link to comment Share on other sites More sharing options...
Blueadventures Posted October 12, 2022 Share Posted October 12, 2022 On 10/10/2022 at 1:25 PM, APenNameAndThatA said: I copied this idea from Youtube. That is Bourke, NSW, with the hole in their parking area. For less than $200 you can get a less than 0.5 kg jack from Peter Anson Engineering. I have one and the need to remove a wheel is no trouble. Worth the money spent the first time you use it. Imagine need to source support and or dig a hole and hot humid temp. It's a bugger. 1 1 Link to comment Share on other sites More sharing options...
spacesailor Posted October 12, 2022 Share Posted October 12, 2022 Jacks Fail , when the wheel is too low to use ' jack ' . 4X4 driving I carry an " exhaust jack " , Just push it under the car away from heat , & the engine lifts the car high enough to get that jack or anything available to make vehicle' safe ' to work on . Also I saw a " half wheel " jack , were you put said H W Jack under axle move forward & wheel it up high . Been there done that . LoL spacesailor 1 Link to comment Share on other sites More sharing options...
facthunter Posted October 12, 2022 Share Posted October 12, 2022 Our Planes are so light they need BuGG@ all to lift one side of them, especially if they are already tilted the right way. The "thing" must not slip though.. Nev 1 Link to comment Share on other sites More sharing options...
Blueadventures Posted October 13, 2022 Share Posted October 13, 2022 53 minutes ago, facthunter said: Our Planes are so light they need BuGG@ all to lift one side of them, especially if they are already tilted the right way. The "thing" must not slip though.. Nev Agree; however solo its difficult. Link to comment Share on other sites More sharing options...
Blueadventures Posted October 13, 2022 Share Posted October 13, 2022 1 hour ago, spacesailor said: Jacks Fail , when the wheel is too low to use ' jack ' . 4X4 driving I carry an " exhaust jack " , Just push it under the car away from heat , & the engine lifts the car high enough to get that jack or anything available to make vehicle' safe ' to work on . Also I saw a " half wheel " jack , were you put said H W Jack under axle move forward & wheel it up high . Been there done that . LoL spacesailor Spacey google Peter Anson Engineering and see how low his new design is and at 450 grams. Excellent product and he has a range of other aircraft stuff. Link to comment Share on other sites More sharing options...
onetrack Posted October 13, 2022 Share Posted October 13, 2022 Blueadventures has nailed it, these Anson jacks would have to be the ducks gonads - light, simple designs, and specifically designed for light aircraft. http://www.ansoneng.com/lightweight-screw-jack/ 1 Link to comment Share on other sites More sharing options...
facthunter Posted October 13, 2022 Share Posted October 13, 2022 None of that is excessively priced and It's LIGHT.. Nev 2 Link to comment Share on other sites More sharing options...
spacesailor Posted October 13, 2022 Share Posted October 13, 2022 It does look good . spacesailor 2 Link to comment Share on other sites More sharing options...
