lyle janke Posted November 5, 2022 Share Posted November 5, 2022 hi all i know this is an old topic but i want to see who has recently done any work on U/C wheel alignment ?? i have asked jabiru the supported method pack with washers -test /check & flock final result nowhere in the responses did i read how you all made bolts holding axle fit ( 1 response "i just bent the bolts " jabiru suggest -"elongate holes in leg until the bolts slide through the assy " ) i wondered if instead of washer packing & flocking i could get a 3D-printed shim (what material ?) a machined metal shim ? or use JB -weld liquid steel to flock the washer method instead of resin who has any thoughts or used any of suggestions to solve camber problem ?? thanks for your thoughts Link to comment Share on other sites More sharing options...
