Tracy O'Brien Brakes
Have received the instructions but no mention of "bedding in".
The brakes will only hold to about (Rotax) 3500 engine rpm. This is just okay for ignition checks but it would be better to be able to get to 4000 rpm. I using  MIL-H-5606BB (Aircraft) hydraulic fluid and there are no air bubbles (that I can see) in the system - any suggestions on how to improve my brand new brakes (only taxied once) will be most welcome.
My ' disc ' brakes were woefully out of ' pad ' alignment , so I taped fine sandpaper either side of the disc , then rubbed the protruding pad material down to an better fit , using the disc as a rubbin Block .
spacesailor
