440032 Posted January 28, 2023 Share Posted January 28, 2023 (edited) A friend has asked about instrumentation for a 2 stroke aircraft engine. It's air cooled. I suppose it needs RPM, CHT, EGT? and volts would be nice. Anything else? Then - what to get? Separate eg VDO gauges or some electronic singles, or, or what? Or, some EFIS something with everything he'll need too, ASI, ALT, etc basics Something not a lot of expense, less than say a $kyview. Probably needs a radio too I guess. Doesn't need inbuilt mapping/charts. MGL something? Kanardia? This is a simple aircraft with not a lot of panel room, bare basics only needed, nothing gold plated. (So Garmin GTHO-XU1 GTS E49 is off the table.) I only know steam gauges myself but I'll have to admit they seem to be going the way of the dodo. (and taking me with it). Edited January 28, 2023 by 440032 Link to comment Share on other sites More sharing options...
Thruster88 Posted January 28, 2023 Share Posted January 28, 2023 If it is a rotax, 503? with the factory recommended jets in the carburetor(s) then as a completely satisfied operator of rotax 377,503 and 582 engines for 38 years now just need RPM. Fuel pressure is next thing I would add. 1 1 Link to comment Share on other sites More sharing options...
440032 Posted January 28, 2023 Author Share Posted January 28, 2023 No, not a Rotax, something a bit more modern and I'd imagine equally as reliable if well cared for. Link to comment Share on other sites More sharing options...
Methusala Posted January 30, 2023 Share Posted January 30, 2023 (edited) Check out Grand Rapids Technologies Engine Information System. 2x cht, 2x egt, RPM, Total engine hrs, Volts, OAT; all with selectable limit alarms. Good value for less than $800 I believe. (Or go with T88 - good engines and reliable.) Edited January 30, 2023 by Methusala addition 2 Link to comment Share on other sites More sharing options...
440032 Posted January 30, 2023 Author Share Posted January 30, 2023 I shall pass that on - thank you! 1 Link to comment Share on other sites More sharing options...
