    Register Log in
Sign in to follow this
eloigorri
Tecnam P92JS Stall warning buzzer location
Hi
I am trying to locate the Tecnam P92JS Stall warning buzzer location. Mine has stopped working and l would like to fault find. If I recall the sound comes from above. l am guessing it is somewhere buried near one of the wing roots in the cabin?
The MM does not specify the location or the specific part. I figure it must be some kind of basic piezo electric buzzer 12v.
Any pointers gratefully received.
Ed
don't know eloigorri but its not a big task to remove the plastic cabin lining above - for a look
................... your comment re stall warning could make an another interesting topic - I'll try that in 'general discussion' - thanks
HiI am trying to locate the Tecnam P92JS Stall warning buzzer location. Mine has stopped working and l would like to fault find. If I recall the sound comes from above. l am guessing it is somewhere buried near one of the wing roots in the cabin?
Ed
You got me thinking now as to where its located on our Sierra . It wont be in our roof because thats a canopy . And i cant recall seeing behind the panel. Though that's a logical place for it.
By the way you have checked the stall actuator out on the wing? They can suffer damage ( bent )
You got me thinking now as to where its located on our Sierra . It wont be in our roof because thats a canopy . And i cant recall seeing behind the panel. Though that's a logical place for it.By the way you have checked the stall actuator out on the wing? They can suffer damage ( bent )
I found the buzzer behind the upper side panel by the pilots head, held in by two screws. The buzzer had failed.
It was easy enough to change out.
Cheers. E
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
