WestCoast Posted July 5, 2008 Share Posted July 5, 2008 Having to remove the wheel when away from home base in the event of a puncture can be a problem if you don't have the right tools. Undoing the securing bolt (KA4020503) can be a hassle although I have released it using a shifter, however you can potentially damage the bolt head so I have had a special socket made up for the purpose. It's not expensive to fabricate as the barrel is made out of an old trailer jockey wheel and there is not a lot of welding to do. The drive size can be made to suit whatever you have in your toolkit. Link to comment Share on other sites More sharing options...
airangel Posted July 6, 2008 Share Posted July 6, 2008 Wheel socket spanner David, Made mine up by forming a tube spanner out of appropriate sized 2mm tubing. Also purchased a light weight scizzer jack from the wreckers [Daihatsu I think] and carry an el cheapo [500grms] $8 00 electric pump, until it fails ,its been marvellous. Link to comment Share on other sites More sharing options...
wags Posted July 8, 2008 Share Posted July 8, 2008 Stand-by air pump for tyres Has anyone had experience with the Cyclaire pump? http://www.just4oz.com/ It's certainly small and light enough, but can it handle the job? Wags. Link to comment Share on other sites More sharing options...
Admin Posted July 8, 2008 Share Posted July 8, 2008 Clear Prop have had the pump in stock for some time: http://www.clearprop.com.au/index.php?target=products&product_id=30532 and it was a hit at Natfly this year - several aircraft had punctures and they came over to the Rec Flying tent and got one of them. Link to comment Share on other sites More sharing options...
